Front axle options
PostPosted: Sat Apr 03, 2004 1:52 pm    Post subject: Front axle options Reply with quote
After seeing Outlaw's D60 (drool) it has me thinking about front axle options. I don't have any immediate plans to go larger than 35's but I've been thinking about my options. I'm not happy with the TJ's steering setup and I've looked at an HP D30 with WJ knuckles to get the tierod up higher and larger brakes. But is it worth the trouble? A D44 doesn't do much for me since everybody wants an arm and a leg for them. So let's discuss, what would be your ideal front axle set-up? Mr. Green
Tx Outlaw
PostPosted: Sat Apr 03, 2004 6:23 pm    Post subject: Reply with quote
I ran 37's on my D30 with Warn inner and outer shafts (had the 5 on 4.5 hub conversion and full detroit with 4.56's) and never broke anything on the front axle.
Can you run the WJ knuckles on the TJ 30? Might look into that or check into flipping the tie-rod to the top of the stock mounts. I've seen a kit for this, but can't remember where.
Chuck
DozerDan
What the deuce?
What the deuce?
PostPosted: Sat Apr 03, 2004 6:28 pm    Post subject: Reply with quote
HP is only some 10-15% stronger than LP, if it were me, i would take your d30, get some alloy shafts and ctm's for it and call it a day.
the strength increase in a d44 is only marginal and hte cost offset to build a 44 is great. So for your application i would think building your d30 is more than adiquate.
You can also add the knuckles, but that is not really a strength issue, its a clearance one.
PostPosted: Sat Apr 03, 2004 7:24 pm    Post subject: Reply with quote
Yeah, I'm thinking the 44 just isn't worth the cost. ORGS is making spacers for the WJ knuckles. You end up with larger brakes (about 2" bigger) and dual pistons calipers plus it moves the tie rod up some.
I've seen the HP D30's go for $150-200 on ebay but I've already got the gearing and locker up front in my existing axle.
Since we're on the subject (though I'm not considering it), I've read that the TJ rear D44's use the same axle tubes as the D35's. Does anybody know if the fronts are much different than the D30's?
'drack
▲▼webwheeler▼▲
▲▼webwheeler▼▲
PostPosted: Sat Apr 03, 2004 7:40 pm    Post subject: Reply with quote
See, that's where my justification for the HP30 comes in. I'm looking at using a Super30 kit, so adding a cheap used housing and set of gears is a minimal add-on. Your case wouldn't make it very prudent since you wouldn't be replacing the stuff that the Superior kit comes with like ya said. I dunno, I'm in the same boat. Don't ever plan on going bigger, really, I don't eyebrows . Money is always gonna be a factor, so my ideal setup isn't gonna become a reality so I don't really plan that sorta stuff. Not really anything constructive, but it kinda helps justify if the HP30 can be justified in one case and considered a waste in another. I think most of us agree that a D44 (unless you're talking one helluva bargain/building it yourself/setting your own gears/et al.) isn't really that much better than going with the HP30, so is starting to really get dismissed as "the next step up" in axles.
Drink more Ovaltine!!!
qadhafi
Club Moderator
PostPosted: Sat Apr 03, 2004 9:11 pm    Post subject: Reply with quote
I personally don't have any experience with this, but I read it in a magazine recently (4WD's Off Road Adventures Magazine).
The GM 10 bolt axle is supposed to be hella strong AND about half the price of a D44. I guess maybe call around to a boneyard to look for one. I haven't even tried googling it yet. Like I said, I just read about it. Rolling Eyes
Back from the Dead??
PostPosted: Sun Apr 04, 2004 7:16 am    Post subject: Reply with quote
Yes, the front TJ D44 is a TJ D30 with a D44 center section and the D44 inner shafts. Everything on the housing from the differential out is the same as a D30. Everything internal from the U-joints out is the same as a D30.
