Engine "racing" at 2k RPM
flyfishboston
PostPosted: Mon Apr 12, 2004 5:25 am    Post subject: Engine "racing" at 2k RPM Reply with quote
Well... I really don't quite know how better to pose the question, so here's my problem.
(1998 5.2L) I'll be driving on the hi-way at about 70mph (cruise control is not on) and will hit a seam or small pot hole in the road and the tach will jump a few hundred RPM then return to 2K. (Note, I've heard of a simular condition where the transmission is hunting for gears, but not so in this case, the transmission is fine). Now this is what mystifys me the most... when I am accelerating at the same speed, and hit the same seam or pothole, all is well.
Anyone have this problem?
I've replaced the IAT and cleaned the port and TB... could it be the TPS?
PostPosted: Mon Apr 12, 2004 9:01 am    Post subject: Reply with quote
It could be the TPS.. But I would think maybe check the Crank Position sensor.. .IT could be loose or something that may account for the sudden surges but it wouldnt explain why it doesnt do it while accelerating in the same spot... That is quite a problem you havethere... YOu are absolutly sure its not tranny related??
It Just seems like a weird engine prob. But with electronic engines it could be any sensor..
I had a problem where If I turned to the right all my lights would dim..
Then come back on .. Then if you hit the brakes hard same thing..
Turned out to be a bad battery ground...
Took me a week to find a 30 second fix..
Good luck with yours..
Carl
hrjaw
PostPosted: Tue Apr 13, 2004 6:46 am    Post subject: Reply with quote
I am actually having somewhat of a similiar problem with my 99 WJ 4.0. all of a sudden it has decided to race at 1500 rpm's, but only when in nuetral or park. i recently jsut changed the plugs, and put in platinums, so not sure if it would be as simple as a plug problem. and it does not always do it. it comes and goes, and is driving me nuts. i checked and re-checked all hoses to make sure it was not a vacuum leak, adn at this point am dumb founded.
Roger
H.R. Jawharjian
