Mike Green cage build up..large pics
Goto page Previous  1, 2
billyji
PostPosted: Mon Apr 19, 2004 10:13 am    Post subject: Reply with quote
Frank is a bending fool
Rob is a wleding fool
lmao
I also have to thank Sheep and Claudia they have been real troopers for anything that has been needed. I think a plasma cutter will be at their house soon.
eveyone else. thank you so much for everything and anything you have been doing
Mike G
ps their will be a hood or part of one....lol then the plan is for my old side skins,maybe part fot he cowl and some jeep grill NARROWED lol
sawzall solves all
++++++ Sponsor of http://www.getbent4x4.com dont miss all the action ++++++
=== Pro-Tools Bender Dealer ===
http://www.mikegreen4x4.com
http://www.blacksheep4x4.com
PostPosted: Tue Apr 20, 2004 1:22 am    Post subject: Reply with quote
Looking great. Cool
billyji
PostPosted: Tue Apr 20, 2004 8:46 pm    Post subject: Reply with quote
can the mod delete one of my posts above. i cannot find the delete post button on the edit page
thanks Mike G
sawzall solves all
PostPosted: Wed Apr 21, 2004 12:33 am    Post subject: Reply with quote
Done deal. Wink
billyji
PostPosted: Mon Apr 26, 2004 7:56 am    Post subject: Reply with quote
[QUOTE=Electric Sheep]SATURDAY,
APRIL 25th
BLING!
Something radical has happened....
Notice how LOW the engine is sitting?
Mike lowered the motor three inches! There's still a lot
of work to do on it, but the purpose of this is to
lower the center of gravity AND to allow the hood and
cowl to sit lower for better visibility.
Here you can see how the cage is coming together. The main
side bars come all the way back and cross before connecting
to the rear main bar.
You can really see how everything is coming together.
The double-tube frame, the side sliders, the rear main
bar, the main a-piller side bars, the b-pillars, and
the radiator hoop all in place now. The hood and cowl
are also cut to size (you can sort of see the cowl pieces
on top of the trash can behind Mike).
That's all for now. I couldn't make it over sunday, so I'll
try to run over to Mike's this evening and take pictures of
the things they accomplished.
Very Happy[/QUOTE]
sawzall solves all
billyji
PostPosted: Tue Apr 27, 2004 8:28 am    Post subject: Reply with quote
[QUOTE=Electric Sheep]MONDAY,
APRIL 26th
New garage door handle installed so FrankN won't smash his fingers again.
Dash bar, a-pillar spreader, and b-pillar spreader tacked in. Notice the
b-pillar spreader is set back a couple of inches from the actual b-pillars.
This is for headroom, and it will tie in better with the rear "X".
Here you can see how the hood and cowl (what's left of it, anyway) will
sit in relation to the dash bar. Still need to build a firewall.
Bling! The old grille is gone, replaced with lightweight chrome
which has been narrowed to match the previously narrowed hood.
You can really see how narrow the whole rig is gonna be now.
Even though everything is just clamped on right now, it's really
starting to come together. It's easy to visualize where this project
is going and what it *should* turn out like.
So FrankN is in Houston, and Mike is leaving tomorrow for a week-long
family vacation. This project won't see any more work for a while, but
the next step is probably going to be building the "X" over the cockpit
and another "X" behind the seats. Then there's the seat mounting bars,
the new upsidedown cross member, the firewall, etc.
TONS of stuff left to do.
Smile[/QUOTE]
sawzall solves all
billyji
PostPosted: Sat Jun 12, 2004 8:03 am    Post subject: Reply with quote
Originally posted by Frank N
[br]These are not in any particular order, and they are over a few weeks w/ of work.
Mike thinking about the rear suspension. Checking out different ideas.
Here is the removalbe tranny mount in place.
same mount from the bottom side.
The rat's nest of lines that I have to relocate.
Here is the tranny mount before it was installed. The two angles on the end are tacked together to keep everything lined up dring installation.
Here you see the recess for the heads of the tranny mounting bolts so mike is less likely to snap them off.
Here I am on top of things. [:p]
Here is where Mike was trying to show me how he wanted the gas tank mounted.
The winch plate welded in place. It will have a gusset tube that comes up to the radiator support that matches up with the support on the engine side.
Windshield brace.
Checking out steering wheel location.
Patrick is not ammused.
Another rats nest picture.
This is the shot of the bracket that mounts the cowl
rear lower links went on last night...uppers tonight
Mike g
sawzall solves all
Page 2 of 2
