airbag light came on ,and gauges stopped working?
illumin8em
PostPosted: Mon Apr 19, 2004 7:05 pm    Post subject: airbag light came on ,and gauges stopped working? Reply with quote
airbag light came on, and gauge stopped woking today when I hit a bump, then came back on. Now they go back and forth when it's bumpy. Any suggestions?
black 98 TJ
R.E. sf 3.5" 33"x12.5" MTRs 4.56 gears, all in boxes
PostPosted: Mon Apr 19, 2004 7:13 pm    Post subject: Re: airbag light came on ,and gauges stopped working? Reply with quote
Sounds like you've got a loose contact or wire somewhere...possibly a bad ground. I'd have to check the wiring diagrams to figure out exactly what would cause it (I'm at work now).
If there's no response before then, I'll check in the morning when I get home.
Steve
PostPosted: Mon Apr 19, 2004 7:31 pm    Post subject: Reply with quote
This used to happen in my 97 fairly frequently and occurred 3x in the 99 recently. Basically, the long term solution is to uninstall your gauge cluster, slightly bend the tabs a bit to maintain better contact, then reinstall the cluster. That's the labor "intensive" solution as there's a bunch of bolts and plastic panel pieces to remove in order to do it. But it's not difficult.
The short term quick solution, smack the top of the cluster with your hand. Everything should pop right back up until it acts up next time.
Upstate Chili
PostPosted: Sat Apr 24, 2004 2:26 pm    Post subject: Reply with quote
Here's a write-up
http://www.jeepmadness.com/guages.htm
marco
PostPosted: Sat May 15, 2004 4:30 am    Post subject: Reply with quote
It's happening the same to my TJ 97.
Does not need a bump, just randomly the gauges go on and off (mostly off) and airbag light is on.
Did you find any solution?
My service shop is getting crazy...already swapped the complete instruments (tacho, speed....everything) with another TJ. Mine works on that but the other has the same problem on mine!
No speed and no rpm too.
Please help me!
Thanks
PostPosted: Sat May 15, 2004 5:35 pm    Post subject: Reply with quote
Please help me!
Thanks
Marco, first...I deleted your thread since no one had responded to it and you found this thread that deals with the same problem.
Have you tried what I suggested above? I know you said you swapped clusters, but if it's a problem with the connector not making adequate contact, I don't believe a different cluster would fix the problem. Try just slightly bending the tab in the connected so they fit tighter in the connector on the cluster. This fixed mine.
macb
PostPosted: Sun May 23, 2004 7:04 pm    Post subject: Reply with quote
follow the link to the write-up...this has fixed several jeeps. The problem is more common than you would think.
The difference between Genius and Stupidity?
Genius has limits...
H2 Recovery Team and NO BLING Gear!
marco
PostPosted: Mon May 24, 2004 4:22 am    Post subject: Reply with quote
that link just take me to a site selling stickers....
el_dubya
PostPosted: Thu Aug 02, 2007 7:49 am    Post subject: Reply with quote
when I try the jeepmadness link it takes me to some search thingy madoo. Anybody have a new link or could post what the writeup was?
Dub
'98 TJ SE
15x7 ProComp Series 51 Rock Crawler Wheels
31x10.50 General Grabber AT2's
Taurus Fan
Uniden PC68 Elite CB
