Front End Torque Specs.
Jasper
PostPosted: Sat Jun 19, 2004 9:13 am    Post subject: Front End Torque Specs. Reply with quote
Swapping front axles. Does anyone have torque specs handy? Looking for upper and lower ball joint, hub/bearing assembly and axle nut. Thanks for the help.
Has anyone seen another web site like torquespecs.com? It's a pretty good reference, just nothing for later models.
PostPosted: Sat Jun 19, 2004 10:54 am    Post subject: Reply with quote
From the '97 FSM:
upper 80 ft/lbs
lower 75 ft/lbs
Hub to knuckle bolts 75 ft/lbs
hub nut 175 ft/lbs
