XJ Tech writeups
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Cherokee Forum
PostPosted: Wed Jun 23, 2004 12:54 am    Post subject: XJ Tech writeups Reply with quote
So for the last few months, I've been putting together a list of various XJ writeups as I've stumbled across them. The goal was/is to put together a kick ass list of tech reference for XJ's. What's here so far is pretty formidable, but there is always room for improvement. So to all you XJ guys and gals out there, ya'll got any more? If so PM me with them and I'll add 'em here.
Thanks to CoreyXJ, 'Drack, Drake69, Kacon and Vics89XJ for their contributions.
STROKING A 4.0L ENGINE
http://www.jeep4.0performance.4mg.com/stroker.html
ODBI & ODBII COMPUTER CODES
http://jeephorizons.com/phpbb/viewtopic.php?t=2719
TIRE SIZE COMPARISION/CONVERSION CALCULATOR
http://www.dakota-truck.net/TIRECALC/tirecalc.html
XJ LIFT/TIRE COMBO GUIDELINE
http://jeephorizons.com/phpbb/viewtopic.php?t=1423
HOMEBREW T-CASE DROP
http://go.jeep-xj.info/HowtoTCdrop.htm
LIFT INSTALLATION WRITEUPS
http://www.off-road.com/jeep/cherokee/xjtech/suspension/liftbasics.html
http://www.rocklizardfabrications.com/home_brew_budget_boost.htm
http://jeephorizons.com/phpbb/viewtopic.php?t=1759
http://jeephorizons.com/phpbb/viewtopic.php?t=1904
http://www.4x4wire.com/jeep/tech/susp/xj_ome_tflx/
http://fm2cd.com/97XJ/xj_budget_boost.htm
FIXING BROKEN UPPER SHOCK BOLTS
http://jeephorizons.com/phpbb/viewtopic.php?t=2016
FENDER TRIMMING
http://www.jeepin.com/features/chop/index.asp
http://jeepin.com/features/stageone/index.asp
http://www.jeepin.com/features/reartrim/index.asp
http://www.rocklizardfabrications.com/fender_trimming.htm
PICS OF A D35 AND A CHRYSLER 8.25 REAR AXLES (8.25 is on the left, D35 is on the right)
http://www.rocklizardfabrications.com/C_8.25_Picture.jpg
NUETRAL SAFETY SWITCH REBUILD
http://jeepin.com/features/nss/index.asp
REAR MAIN SEAL REPLACEMENT
http://jeepin.com/features/rearmain/index.asp
FIXING BLOWBY (OIL IN AIR FILTER)
http://www.off-road.com/jeep/cherokee/xjtech/engine/40ltr/blowby.htm
http://www.off-road.com/jeep/cherokee/98/04_apr/valvecover/cover.html
CLEANING THE THROTTLE BODY
http://www.off-road.com/jeep/cherokee/xjtech/engine/tbody.htm
REPLACING THE WATER PUMP
http://jeepin.com/features/waterpump/index.asp
WHEEL BEARING REPLACEMENT
http://www.off-road.com/jeep/cherokee/2001/02_feb/bearing/index.html
CHANGING U-JOINTS (applies to both driveshaft and axle shafts)
http://jeepin.com/features/ujoint/index.asp
http://www.4x4wire.com/tech/axle/ujoint/
MAKING HOMEBREW DISCOS
http://jeepin.com/features/discons/index.asp
http://www.off-road.com/jeep/cherokee/98/08_aug/disconnect/disconnect.html
AW4 TRANSMISSION OVERRIDE SWITCH
http://www.jeepbarracks.com/modules.php?name=News&file=article&sid=19
SPEEDO GEAR SWAP FOR BIGGER TIRES
http://www.off-road.com/jeep/cherokee/98/07_jul/speedo/speedo.html
http://jeepin.com/features/speedogear/index.asp
CONVERTING CLOSED COOLING SYSTEM TO OPEN
http://www.off-road.com/jeep/cherokee/98/12_dec/radiator/radiator.html
BRAKE JOBS - FRONT
http://jeepin.com/features/discs/index.asp
http://go.jeep-xj.info/HowtoFrontDisks.htm
BRAKE JOBS - REAR
http://jeepin.com/features/drums/index.asp
http://go.jeep-xj.info/HowtoRearDrums1.htm
BORING A 91+ 4.0L THROTTLE BODY OUT TO 60mm
http://jeepin.com/features/throttlebody/index.shtml
http://go.jeep-xj.info/HowtoTBboring.htm
XJ ARMOR INSTALLS
http://jeephorizons.com/phpbb/viewtopic.php?t=990
ZJ TIE ROD CONVERSION (Applies to both XJ's and TJ's as they use the same linkage)
http://www.jeephorizons.com/tech/tjtierod/
http://www.stu-offroad.com/misc/tierod-1.htm
D44 AXLE SWAP
http://jeephorizons.com/phpbb/viewtopic.php?t=1977
http://www.pirate4x4.com/tech/billavista/D44_buildup/D44.htm
REAR DISC BRAKE CONVERSIONS
8.25 (these could also be used as reference for a D35 as well)
http://home.swbell.net/rriojas3/reardisk.html
http://cherokeekid5.tripod.com/zj_discs_on_a_xj.htm
http://geocities.com/dcpaschal/mitch.html
D44
http://www.off-road.com/jeep/cherokee/2002/08_aug/reardisc/index.html
BUILDING A STORAGE DECK IN THE CARGO AREA
http://www.jeepin.com/features/cargobed/index.asp
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Cherokee Forum All times are GMT - 8 Hours
