Front Diff is leaking
sonofamitch
PostPosted: Mon Sep 13, 2004 8:05 am    Post subject: Front Diff is leaking Reply with quote
My front diff is leaking, what is the proper way to address this? Shocked
My name is MUD.
PostPosted: Mon Sep 13, 2004 8:15 am    Post subject: Reply with quote
Where's it leaking from? The axle tubes? Out the front cover? From the pinion seal?
sonofamitch
PostPosted: Mon Sep 13, 2004 8:35 am    Post subject: Reply with quote
The pinion seals.
My name is MUD.
PostPosted: Mon Sep 13, 2004 8:52 am    Post subject: Reply with quote
You'll need to replace the pinion seal. Here's a quick write-up on both the Dana 30 and 35.
sonofamitch
PostPosted: Mon Sep 13, 2004 8:58 am    Post subject: Reply with quote
Thanks man. Very Happy
My name is MUD.
PostPosted: Mon Sep 13, 2004 9:41 am    Post subject: Reply with quote
Be sure to take lots of photos when you do yours so you can do a write- up for the tech page. Wink
