adj. ca for 231 swap
dutman
PostPosted: Sun Sep 19, 2004 12:30 pm    Post subject: adj. ca for 231 swap Reply with quote
I'm thinking about swapping my 249 t-case for the 231. I did the f>r swap and have about 4" lift with 31" tires. I'm on the stock ca's so my rear axle is far from centered. From what I've read, the 231 case is longer than the 249. So between my axle being moved forward and the 231 being longer...my driveshaft is going to be too long...right? Should I have my drivshaft shortend (if possible), or should I get adj. control arms?
95 ZJ 4.0 F>R=4" BFG AT 31x10.5's on black steelies
PostPosted: Sun Sep 19, 2004 6:08 pm    Post subject: Reply with quote
You can either lengthen your stock control arms if you have access to a welder or buy adjustables..
If you never plan on going long arms .. Adjustable is the way to go..
The 231 is only about 1 1/2" longer.. But it will probobly be about 1/2 " to long..
I had to push my axle back 1 3/4" to recenter it and get the shaft the right length..(5.5" lift.)
Carl
forexfour
PostPosted: Wed Sep 22, 2004 9:42 am    Post subject: Reply with quote
My 249 to 231 swap went fine. The driveshaft were not to long or to short for my 97 ZJ.
I have the 4.5" RE lift and 32's.
www.caoffroaders.com
