help in installing KC fog's, wiring through firewall
rhr0812
PostPosted: Fri Oct 29, 2004 5:44 am    Post subject: help in installing KC fog's, wiring through firewall Reply with quote
2000 wrangler, mounted the KC's and I took apart the dumb switch plate to find a blank connection attached behind it. Can I use this instead of running my wires all over the place. If so, how do I find the end of the run, and can I install the red KC light wire to the fuse box. Oh, how do you open the box and where do you connect. Seems to be easier this way than running the KC green and white wire through the firewall which I cannot find a hole to get through. I would appreciate any help on this!!!
Regards
PS
Would it also be possible to tap into the cig lighter (don't need it) and use this as the switch source of power since its wired through the wall?
PostPosted: Fri Oct 29, 2004 1:15 pm    Post subject: Reply with quote
The stock wiring is likely too small for the amperage drawn by those lights. Run the wires that KC gave you and put your switch where the blank spot is located.
