Can We Change the Gears
majikxms
PostPosted: Thu Nov 11, 2004 4:22 pm    Post subject: Can We Change the Gears Reply with quote
Subject stock vehicle is a 2004 TJ X series with a D30 front/D35 rear, 3.07 gears, 29" tires. As far as I can tell the gear to rpm ratio charts are pointing us to a 4.56 gear set to keep the rpm's within optimal levels while running 33's. Can we do an upgrade to 4.56 in the stock setup. I ask this because of the following:
When replacing 3.54 and numerically
lower ratio gear sets with a 3.73
or higher gear, the case must be
changed to a 3.73 and higher case.
What does it mean "the case must be changed," can we do it and what do we need to get? Thanks.
Dale
PostPosted: Thu Nov 11, 2004 4:31 pm    Post subject: Reply with quote
You need new carriers to swap from 3.07s to 4.56s.
My recommendation would be, at a minimum, add in front and rear TruTracs (a gear based limited slip) and you can gain a traction aiding differential and get the proper carrier in a single part. A LSD wouldn't hurt the D35 as bad either if you get a bit heavy-footed offroad compared to a locker.
T.O.W. Vehicle
PostPosted: Thu Nov 11, 2004 6:58 pm    Post subject: Reply with quote
My LSD really helps me get through so pretty tough stuff.
"T.O.W. "= Tent On Wheels.
Best Top Sailcloth RAT
RE 4.5"Super Flex Lift
AA HD SYE
JKS Quicker Disconnects
Shrockguards
kygreenyj
PostPosted: Sat Nov 13, 2004 7:29 am    Post subject: Reply with quote
yeah it really takes the edge off. very relaxing stuff Very Happy
06 Ford Escape Hybrid
03 KLR 650
