Heat will not come through dash vents
Goto page 1, 2  Next
Keithtj
ARLI$$
ARLI$$
PostPosted: Fri Dec 17, 2004 6:43 am    Post subject: Heat will not come through dash vents Reply with quote
Ok, I'm still having this problem and would like to get it fixed during my two week christmas break! Heat will not come through my dash vents, it comes through the defrost vent and the floor vents but not the dash vents. Any ideas as to why this happening?
My Morning Jacket
Black2001TJ
Leopard Skin
Leopard Skin
PostPosted: Fri Dec 17, 2004 7:53 am    Post subject: Reply with quote
I've seen this before... Look in a manual, I believe there is a lever or cable or something that turns when you select the different "zones" for the heat.. If you replace that (I think I remember it being cheap, I helped a friend with the same issue years ago so it's cloudy) you should be good..
Keithtj
ARLI$$
ARLI$$
PostPosted: Fri Dec 17, 2004 10:55 am    Post subject: Reply with quote
Thanks, when I get back to Louisville, we'll take my dash off and give it a look!
My Morning Jacket
PostPosted: Fri Dec 17, 2004 11:21 am    Post subject: Reply with quote
Before you go yanking the dash off, be careful with the airbags. I don't want to read about you having a screwdriver embedded in your sinus. Do you have the FSM? If you go to the HVAC removal/installation section, it shows you how to pull the temp control panel from beneath the radio. I'd look at those connections to make sure everything is still hooked up and also check to be sure there's enough vacuum to operate the blend door (not the right name, but I can't think of it right now.)
Keithtj
ARLI$$
ARLI$$
PostPosted: Fri Dec 17, 2004 11:24 am    Post subject: Reply with quote
Shit, Corey is doing the work now! I need to get my hands on the fsm now, if some one has one for a 97 4cyl, pm me!
My Morning Jacket
95sahara
PostPosted: Fri Dec 17, 2004 12:10 pm    Post subject: Reply with quote
Not the blend door, the mode door. The blend door adjusts the temp. The mode door adjusts air flow. Just helpin you think.
PostPosted: Fri Dec 17, 2004 12:24 pm    Post subject: Reply with quote
Exactly. thanks
majikxms
PostPosted: Fri Dec 17, 2004 12:25 pm    Post subject: Reply with quote
Please take a picture of Corey with the phillips up his nose...thanks.
Keithtj
ARLI$$
ARLI$$
PostPosted: Fri Dec 17, 2004 12:45 pm    Post subject: Reply with quote
I will do it, actually I'll have someone else take the pics, I think I might be laughing to hard rofl Finger
My Morning Jacket
T.O.W. Vehicle
PostPosted: Sat Dec 18, 2004 7:12 pm    Post subject: Reply with quote
I too am interested in the final problem. I have a friend that is experiancing somewhat the same thing. Only hers cuts out when she gets on the skinny pedal. Sounds vaccum related to me also.
"T.O.W. "= Tent On Wheels.
Best Top Sailcloth RAT
RE 4.5"Super Flex Lift
AA HD SYE
JKS Quicker Disconnects
Shrockguards
JeepGal
PostPosted: Tue Mar 15, 2005 1:24 am    Post subject: Re: Heat will not come through dash vents Reply with quote
Hey KTJ...did you figure out this problemo? I have the same one Smile
Tam Smile
Keithtj
ARLI$$
ARLI$$
PostPosted: Tue Mar 15, 2005 7:09 am    Post subject: Reply with quote
I am the king of putting things off, I still don't have 4 lo and wheeling is 2 weeks away Shocked and no heat through the vents still.
My Morning Jacket
Ryan Schmaltz
PostPosted: Thu Mar 17, 2005 3:49 am    Post subject: Reply with quote
i had tha same problem.turned out the yellow vaccum got unhooked.
97 4.0L Tj, 3" body, 33X12.5X15 TSL Swampers, MSD Ignition, Warn M8000, Custom front, rear bumpers, nerf bars. In process of swapping diffs, 44 front 9" rear 5.13 gears, making a custom 8" sus. lift with SkyJacker coils. Going to run a 38 Bogger.
JeepGal
PostPosted: Thu Mar 17, 2005 10:42 pm    Post subject: Reply with quote
Awesome, Ill check that tomorrow Smile
Tam
Keithtj
ARLI$$
ARLI$$
PostPosted: Fri Mar 18, 2005 6:47 am    Post subject: Reply with quote
Is it cold enough in Cali to use the heater?
My Morning Jacket
Goto page 1, 2  Next
Page 1 of 2
