engine....
nikon
PostPosted: Mon Jan 10, 2005 9:13 pm    Post subject: engine.... Reply with quote
couple of questions about THIS site.
First off - I am talking about my 95 YJ 2.5l 4cyl...
1. What price and I looking at for the rebuilt?
2. What does Core mean?
3. How good is a rebuilt motor compared to a new motor? Is New a brand new never been put in engine? Which is the better deal? Is it worth the extra couple hundred for the new one compared to the rebuilt?
thanks guys.
LISTEN TO BLACK SABBATH
FM2CDJC Member #10
9. Thou shalt not kill. Unless some motherf****r is coming into your house to take your s**t! - The Nuge
PostPosted: Mon Jan 10, 2005 9:39 pm    Post subject: Reply with quote
OK, first off there's a difference between short and long blocks. A short block will not include cylinder heads. A long block will. If you plan to re-use your heads, then go for the short block.
The "core" is you old engine.
The rebuilt engine will be a used block (re-machined of course). Possibly with re-machined parts (pistons, crank, etc.). Normally, only the bearings, seals, etc. will be new. The new engine will be all new parts...including a freshly cast block.
Me? I would hook my old one and rebuild it in my garage...maybe do a stroker kit too... Finger
Seriously, you'll get the same warranty either way...but if I were you (and my wallet could do it) I would go for new.
WhatWasIThinkin
PostPosted: Tue Jan 11, 2005 12:33 pm    Post subject: Reply with quote
As long as the rebuilt is from a reputable source they can in many ways be better than what comes stock.
Over the life of an engine, they become "seasoned" which basically means that the metal structure has become highly stabilized. A good engine remanufacture will magnaflux the block, head, and crank before they rebuild it. Check to see if the source does this or not. If not, dont bother and look for another source. Magnafluxing is a process of checking for cracks or stress marks of any sort.
If I was in the need of a new engine and had the extra time and money I would also use a good machine shop for that type of work and then assemble the engine myself with high end parts or do the stroker engine like Steve mentioned. Thats the expensive and time consuming route.
IF I was just in a rush to get it back running again and money was tight, then I would go for a rebuilt without a second guess.
Real Jeeps dont wear Bra's
nikon
PostPosted: Tue Jan 11, 2005 8:37 pm    Post subject: Reply with quote
thephantum wrote:
The "core" is you old engine..
i'm a little confused (surprise surprise).........
That mean that they discount that if I give them mine?
I will see about magnafluxing
thanks guys
money is tight and I think i need this done sooner than later paying someone else to do it. Crying or Very sad
i just noticed this....no shipping charge on engines Very Happy
FM2CDJC Member #10
PostPosted: Tue Jan 11, 2005 8:48 pm    Post subject: Reply with quote
No...it's not a discount. More like a deposit. You'll pay a core charge to them, which you'll get back when you return your old engine.
nikon
PostPosted: Tue Jan 11, 2005 10:14 pm    Post subject: Reply with quote
oh. boo
FM2CDJC Member #10
