suspesion lift
demons42
PostPosted: Fri Jan 21, 2005 2:01 pm    Post subject: suspesion lift Reply with quote
I was wondering if it would be possible to fit a rancho lift from a 1993 cherokee sport onto a 1998 cherokee sport. Without doing any major modification with the lift.
Thanks for any help
1998 jeep cherokee sport
PostPosted: Fri Jan 21, 2005 2:08 pm    Post subject: Reply with quote
What size lift is it? If there's an SYE involved in the swap, the driveshaft might not fit...depending on the rear axles in both Jeeps. There's a few inches difference between the driveshafts for D35's and 8.25's
The suspensions are exactly the same though. It will be a bolt in, direct swap.
HTH
Steve
demons42
PostPosted: Fri Jan 21, 2005 2:21 pm    Post subject: Reply with quote
It's a 3.5" lift and my jeep has a 8.25 rear end and i belive the other has a d35.
PostPosted: Fri Jan 21, 2005 2:47 pm    Post subject: Reply with quote
At 3.5" it probably does not have an SYE, so you shouldn't have to touch the driveshaft. Like I said, the suspensions are exactly the same...it'll bolt right in.
Git-r-dun.
Rock On!
Steve
demons42
PostPosted: Sat Jan 22, 2005 11:56 am    Post subject: Reply with quote
thanks for the confirmation
