242 swap in gc
jeepdenman
PostPosted: Tue Feb 01, 2005 3:17 pm    Post subject: 242 swap in gc Reply with quote
ive been reading about the problems that i could have swapping out my t-case for an older 242. i have a 95 gc with a 249 thats goin bad, and i found a 242 from a 92 xj, i was wondering what problems i might run into wit hthe vic, and speedo harness? and how can i fix these problems, if ther are any? thx
PostPosted: Tue Feb 01, 2005 4:57 pm    Post subject: Reply with quote
I think you may have trouble with the VIC.. But I am not sure.. When you get it .. Look at the mode sensor (electric plug..) The VIC reading incorrectly may be your only problem.. But honestly with an 92 case It will probobly work..
The gear mesh will not be a problem and the speedo gear will not be a problem..
Good luck..
Oh and if the worst problem you have is that your VIC says full time all the time or part time all the time ... Is that really a big deal?? Mr. Green
