leaking coolent
bonestajker
PostPosted: Sat Feb 05, 2005 5:50 am    Post subject: leaking coolent Reply with quote
leeking ; drivers side 89 with 4.0 i think it s my freez plugs ,has any 1 ever tryed to remove these ? any tips or sugestions would be apprishated.
thnkx Mr. Green
qadhafi
Club Moderator
PostPosted: Sat Feb 05, 2005 11:04 am    Post subject: Reply with quote
Sure it's not your water pump? I had to replace mine last year.
Back from the Dead??
CoreyXJ
Turkish
Turkish
PostPosted: Sat Feb 05, 2005 11:36 am    Post subject: Reply with quote
Freeze plugs are pressed in like a bushing, so thats not something you want to try and "take out" .... It could be a freeze plug that is leeking though, anythings possible. Can you tell exactly where its coming from??
bonestajker
PostPosted: Sat Feb 05, 2005 10:44 pm    Post subject: Reply with quote
pulled the water pump and put in a new gasket the hoses didnt seem to be to bad , it s kind of hard to pin point the exact location .ie exaust manifold . it seems to be coming from mid to upper level of the block the running along the top of oil pan. not sure if the head would leak like that its my firist 4.0 but it has 210,000 mils and runs strong .the leaks not drimatic but enough that i have to fill the bottle every other day or so .
CoreyXJ
Turkish
Turkish
PostPosted: Sat Feb 05, 2005 10:53 pm    Post subject: Reply with quote
Well its hard to say without seeing it... But if the head were cracked it would leak but it would also affect the way it runs. It is possible that you have some working its way out through the head gasket. With it running shine a light along the seem where the head meets the block and see if you can tell where its leeking out. I know its hard with all that exhaust/intake stuf in the way, but you really have to pin point where it comes from in order to fix it correctly. You dont want to replace one thing if you do not need to....thats what I mean.
CoreyXJ
bonestajker
PostPosted: Sat Feb 05, 2005 11:10 pm    Post subject: Reply with quote
planing on pulling off intake and exaust to see. i didnt think it was the head gasket theres no water in the oil, like i said thoe its my first . just trying to prep for the worst . the chiltion tha i had is kind of vage about that area , or i just missed it . Confused
CoreyXJ
Turkish
Turkish
PostPosted: Sun Feb 06, 2005 8:53 am    Post subject: Reply with quote
The trouble with that is, you could have the exterior side of the HG go bad and the iner walls still be allright so there wouldnt be any coolant in the oil... Once you get it apart let me know.
