HOW DO I GET THE WIRE INSIDE???
little Army guy
PostPosted: Fri Feb 18, 2005 5:04 pm    Post subject: HOW DO I GET THE WIRE INSIDE??? Reply with quote
Today I continued my task of hooking up the off-road lights in my TJ and got it all done, 'cept the part where I'm 'posed to get the wire inside the Jeep. I ran the wire inside the loom as suggested, tested them out and they work fine. Then I secured them to the roof rack and stopped there cuz I really didn't want to drill any extra holes into the body. I know alot of you have off-road lights, and would like to get some suggestions so I can get the lights hooked up and ready to go. THANX. have a great weekend.
Ray
Black2001TJ
Leopard Skin
Leopard Skin
PostPosted: Fri Feb 18, 2005 6:49 pm    Post subject: Reply with quote
If you look under the dash from the driver's side, you should see the firewall... There is a few holes most likely and definitely one with a rubber plug which is really thin... You can pull out that plug (or probably even cut) a small hole in it, put it back in and run the wires.
PostPosted: Fri Feb 18, 2005 7:18 pm    Post subject: Reply with quote
yea check the firewall its where i ran the wire for my amp in me grand
quadna71
PostPosted: Sat Feb 19, 2005 5:02 am    Post subject: Reply with quote
i found that making a slight "/" and a "\" with a razor works well. push the wire through the center of the cross and then a dab of rtv once you done to weatherize it.
chris
2003 TJ Sport
little Army guy
PostPosted: Sat Feb 19, 2005 9:13 am    Post subject: Reply with quote
Thanks for the help guys...here's the TJ outta control.
Ray
Stevo02TJ
PostPosted: Sat Feb 19, 2005 7:07 pm    Post subject: Reply with quote
I drilled two holes in the windshield frame, folded it down, and "fished" the wires through.....it's not the best way for someone without patience....but it's the cleanest set-up in my opinion. I see you already have your answers, but I figured I'd tell you how I ran my wires.
I'll try to get some pics soon if you want to see where I drilled the hole. thumbs
little Army guy
PostPosted: Wed Feb 23, 2005 5:30 pm    Post subject: Reply with quote
Steve-oh, hook me up with those pictures man! I finished the job and it came out ok, I just would like to see your product finished. thanks homie!
Ray
