HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WATER IN AUTO TRANNY
whitesport00
PostPosted: Sat Feb 19, 2005 5:00 pm    Post subject: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WATER IN AUTO TRANNY Reply with quote
i have a 2000 TJ with an automatic tranny how do i keep water out.
Tx Outlaw
PostPosted: Sat Feb 19, 2005 5:43 pm    Post subject: Re: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WATER IN AUTO TR Reply with quote
First thing is to get the tranny flushed, if it's already been flooded. After that, extend the breather up to the top of the firewall in the engine compartment with a hose.
whitesport00
PostPosted: Sat Feb 19, 2005 5:47 pm    Post subject: Reply with quote
where is the vent tube located
already flushed
PostPosted: Sat Feb 19, 2005 6:43 pm    Post subject: Reply with quote
Stay out of water.
Mr. Green
whitesport00
PostPosted: Sat Feb 19, 2005 6:48 pm    Post subject: Reply with quote
be a man
if you can give any helpful info then don't comment. my jeep is not made to baby.[/quote]ehirner
Stay out of water.
2000 TJ SPORT
4.0
31x10.50 BFG A/T KO
Cobra CB channel 4
PostPosted: Sat Feb 19, 2005 7:00 pm    Post subject: Reply with quote
It's probably a rubber tube that comes out the top of the transmission. Crawl around your jeep and look for it. If you're not willing to do that, then Ehirner's advice was perfectly good. no
whitesport00
PostPosted: Sat Feb 19, 2005 7:05 pm    Post subject: Reply with quote
the only rubber tub i see is comming out of the transfer case.
2000 TJ SPORT
4.0
31x10.50 BFG A/T KO
Cobra CB channel 4
PostPosted: Sat Feb 19, 2005 7:30 pm    Post subject: Reply with quote
whitesport00 wrote:
be a man
Starting off on the right foot I see.
It's helpful info. I'm sorry it's not something you prefer to hear.
whitesport00
PostPosted: Sat Feb 19, 2005 7:37 pm    Post subject: Reply with quote
no i just don't need any smarta** comments.
I need help.
2000 TJ SPORT
4.0
31x10.50 BFG A/T KO
Cobra CB channel 4
PostPosted: Sun Feb 20, 2005 5:05 am    Post subject: Reply with quote
Those are your 2 choices. Extend the vent tube (basically, snorkel the tranny) or don't go swimming. Nothing smartass about it, so just relax and lets keep the thread on topic.
I don't know where it is on the TJ auto's. I believe there were 2 autos available in 2000, a 3 speed and a 4 speed. In either case, it would be near the top of the tranny. Like Code said, I would just crawl around under there with a flashlight and look.
HTH
macb
PostPosted: Mon Feb 21, 2005 4:02 pm    Post subject: Reply with quote
probably not a breather hose per se...more likely a breather or expansion port
that is not tubed...my manual tranny was that way also - I had to pop off
the topper and then tube it myself. I believe some of the autos were the same
it was easier to work on by removing the console and pulling the tranny tunnel
covers to get at the top of the tranny on mine.
good luck.
The difference between Genius and Stupidity?
Genius has limits...
H2 Recovery Team and NO BLING Gear!
