1994 grand cherokee rad fan conversion.
quattro
PostPosted: Sat Feb 26, 2005 7:20 pm    Post subject: 1994 grand cherokee rad fan conversion. Reply with quote
I am wondering if anyone has removed the viscous fan clutch and blades and replaced them with a electric fan assembly? I seem to have a problem with the waterpump bearing being pulled forward to a destructive death by the force of the fen. We live in a cooler climate and a alectric fan would save horse power and fuel.
mcracco
PostPosted: Sun Feb 27, 2005 4:36 am    Post subject: Reply with quote
Here's what I have accumulated in anticipation of the same:
http://www.jacksongalleries.com/alex/jeep/taurusfan/
http://www.jeep4.0performance.4mg.com/custom4.html
http://www.off-road.com/jeep/cherokee/98/06_jun/cooling/cooling1.html
PostPosted: Mon Feb 28, 2005 10:46 pm    Post subject: Reply with quote
Check the Tech Forum here I have a writeup for installing it in a Grand.. Very Happy
http://www.jeephorizons.com/tech/fan/
PostPosted: Tue Mar 01, 2005 7:55 am    Post subject: Reply with quote
can you wire it up to the thermostat so when the temp gets to a point the fan comes on?
PostPosted: Tue Mar 01, 2005 10:18 am    Post subject: Reply with quote
Yes... I have one of those.. They are available at autozone for about $24..
Work like a charm also...
PostPosted: Tue Mar 01, 2005 12:09 pm    Post subject: Reply with quote
wiring any different? what kinda HP increase and all that would i get? I6 here
PostPosted: Tue Mar 01, 2005 12:35 pm    Post subject: Reply with quote
I used toggle switches on mine .. (because I do alot of deep water) and I used a Ford started solinoid for the high side.. (Others say this is not good but no problems so far.. (And they are only $9 so I carry a spare..)
For wireing the switch I just cut the power side of the low speed (between switch and fan) and ran it thru the switch..That way switch off still kills the fan no matter what... Very Happy
I can take a picture of where I mounted mine If you want...
Carl
