tj with 2.5L
alx
PostPosted: Mon Mar 07, 2005 6:53 pm    Post subject: tj with 2.5L Reply with quote
ok i just got a 2003 tj with the 2.5 liter engine right now it has 31" tires but i want to fit 32" or 33" tires what would be the best way of doing this and do i have enough power
CoreyXJ
Turkish
Turkish
PostPosted: Mon Mar 07, 2005 9:04 pm    Post subject: Reply with quote
You have enough power there, what size lift is on it? Is it a body lift or suspension lift? Or is it both?
33's will fit on TJ's fine with the right amount of lift.
-CoreyXJ
PostPosted: Tue Mar 08, 2005 12:57 am    Post subject: Reply with quote
I've got 33's on mine currently - going to 34's when I get off my butt and get them mounted. You won't be winning any races, but it's a jeep... Wink
alx
PostPosted: Tue Mar 08, 2005 1:52 pm    Post subject: Reply with quote
it does not have a lift on it now but i have heard and think that a 1 inch body and a 2 inch spacer and shocks is one of the best ways of fitting that size tire
PostPosted: Wed Mar 09, 2005 12:17 am    Post subject: Reply with quote
Well, yeah you can fit that size tire on it but... what are you going to be using it for?
PostPosted: Wed Mar 09, 2005 12:27 am    Post subject: Reply with quote
3" is the general rule for 33's on a TJ. 2" spacers and a 1"BL work but it's not necessarily the best way to do it. It's just the best way to do it on a budget. If you plan to offroad it, you'll eventually want to look into 3" or 4" lift coils.
You might want to also do a motor mount lift to raise the engine with the body as well as to help straighten out the driveline angles.
