Warrior Adventure Rack
Towerassoc
PostPosted: Sat Mar 19, 2005 10:17 am    Post subject: Warrior Adventure Rack Reply with quote
Has any one tried the Warrior Adventure Rack? It mounts on the swing back door and is rated at #200.
Thanks
Bill
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger
PostPosted: Sat Mar 19, 2005 1:18 pm    Post subject: Reply with quote
I believe the rear gate is only rated to 75lbs, if not, it's still nowhere near 200lbs. Add in the leverage cause by that raised rack and you'll be causing yourself some problems.
bltracer
PostPosted: Mon Apr 04, 2005 5:08 pm    Post subject: Warrior Products Rack Reply with quote
I have the WP rack installed on my 97 TJ. I works well. I have had about 100 pounds on it with no problem. It comes with 2 supports that bolt to the body under the door, when pinned, it is solid as heck. Only problem, the support on the hinged side does not allow for the door to open and close, so I have removed it and only put it on when I will have a load of 100 pounds or more...
