Turn signal/Parking light problem
PostPosted: Sun Mar 20, 2005 5:19 pm    Post subject: Turn signal/Parking light problem Reply with quote
Something strange going on - when the temperature is under about 45 degrees outside, one of the turn signals/parking lights (narrowed it down to the driver's side flare light) doesn't work. Headlights off and the turn signal works fine. I've tried replacing the bulb - no change. Any ideas on a next step? Maybe some dielectric grease?
CoreyXJ
Turkish
Turkish
PostPosted: Sun Mar 20, 2005 8:49 pm    Post subject: Reply with quote
I would definetly change the blinker fluid in there.... try using some of the new synthetic stuff - supposed to be the bomb. ??
Uh...er... anyways - sounds like a contact point issue if temperature affects it. Make sure the contact is good and clean and try some of the di-grease. Also move the plug around with your hand... hot and cold expansion/contraction sometimes can be solved by just moving the plug around a little bit.
Good luck with that thing - CXJ
PostPosted: Sun Mar 20, 2005 9:20 pm    Post subject: Reply with quote
Yup. Sounds like a hot expansion/cold contraction on or around the ground for that marker. Switching to the synthetic blinker fluid will help too. rofl
Black2001TJ
Leopard Skin
Leopard Skin
PostPosted: Mon Mar 21, 2005 6:47 am    Post subject: Reply with quote
same issue, I replaced the contacts and soldered them, go!
PostPosted: Mon Mar 21, 2005 10:48 am    Post subject: Reply with quote
Thanks for the idea, gentlemen. At least it's nothing major. Confused
PostPosted: Mon Mar 21, 2005 9:20 pm    Post subject: Reply with quote
laugh laugh laugh
Now let's get a newbie to read that!!!
