drive shafts
sktr7025
PostPosted: Tue Mar 22, 2005 5:37 pm    Post subject: drive shafts Reply with quote
i have 4" lift now. What shafts might i have to replace? Front drive or rear shaft or both.
95 YJ 4" sykjacker 33" BF AT
PostPosted: Wed Mar 23, 2005 12:02 am    Post subject: Reply with quote
Are you installing a slip yoke eliminator or something like that? Or are you having vibrations?
sktr7025
PostPosted: Wed Mar 23, 2005 5:04 am    Post subject: Reply with quote
i think i have a little bit not much. but i am puttting on a 2" BL soon when i get 35" tires. And if i got the DS i was going to get the SYE also.
kygreenyj
PostPosted: Wed Mar 23, 2005 9:05 am    Post subject: Reply with quote
get the sye and the DS skip the 35's and get a 1 inch bl and a mml, you'll have a much better set up
06 Ford Escape Hybrid
03 KLR 650
sktr7025
PostPosted: Wed Mar 23, 2005 9:12 am    Post subject: Reply with quote
what is a mml
PostPosted: Wed Mar 23, 2005 12:24 pm    Post subject: Reply with quote
motor mount lift.
sktr7025
PostPosted: Wed Mar 23, 2005 2:16 pm    Post subject: Reply with quote
why would a motor mount lift help. would that help with tire clearance when i go up to 35" tires?
PostPosted: Thu Mar 24, 2005 12:05 am    Post subject: Reply with quote
Basically, it'll line up the engine with the radiator if you've installed a body lift. In some cases, it'll point the rear output on the transfer case slightly more towards the rear axle.
sktr7025
PostPosted: Thu Mar 24, 2005 6:41 am    Post subject: Reply with quote
so are they easy to install and where is a good place to buy them? will i still need a SYE and a new rear drive shaft and what about the front DS?
DesertYJ
PostPosted: Fri May 13, 2005 1:08 pm    Post subject: Reply with quote
First off, a body lift has nothing to do with your driveline. It raises your "BODY". If you raise the motor mounts it can change the geometry.
I changed my rear driveline after I did my 4" suspension lift because I did not want to drop my belly plate two inches. (It did not make much sence to loose two inches of clearance)
I installed a Tom Wood's SYE and CV drive line. I also added a 1" body lift and raised my radiator 1". (Not my engine) I am still running the stock front drive line. I did not raise the engine because I like the extra room between the engine and hood for air lines and etc...
