Power Steering Gearbox
skidmark
PostPosted: Sat May 14, 2005 4:14 pm    Post subject: Power Steering Gearbox Reply with quote
Can someone tell me if a CJ7 power steering unit is the same as on a YJ? Thanks.
Black 92 YJ, 33" MT's, 4.0 HO, 4.88's, Warn HS9500, Aussie Locker in Front, Lots More on the Way.
PostPosted: Sat May 14, 2005 10:30 pm    Post subject: Reply with quote
I searched and the part numbers for remanufactured ones are close but a little bit off. Do you already have one that you're looking to swap?
skidmark
PostPosted: Sun May 15, 2005 7:43 am    Post subject: Reply with quote
Not yet, but a friend of a friend wrecked his CJ7 Friday night. He is looking at parting it out. I'm not sure if the box survived, I haven't seen it yet. I twisted the out shaft on mine a couple weeks ago, along with a busted axle and busted spring. Tha axle and spring are fixed, but I'm still looking for the gearbox. Thanks for the info.
PostPosted: Sun May 15, 2005 8:21 am    Post subject: Reply with quote
It's worth a try if the price is right and it's not damaged. I just replaced my TJ's with a Dodge Durango box. It was a bit bigger but the only difficulty I had was with the routing of the return line.
