Hitch compatibility 2004 special edition
bassmaverick
PostPosted: Sun May 08, 2005 8:22 pm    Post subject: Hitch compatibility 2004 special edition Reply with quote
Will and is this the hitch system that hides behind the bumper with only the receiver visible via a hole cut in the bumper?
What is the best hitch system for a 2004 Special Edition?
[url]http://checkout.mainstreetcommerce.com/(gubid345bbggke55bdx12c45)/item_detailed_photo.aspx?auction_guid=b8a52992-e556-4baa-bc3a-311fa6b31dd7[/url]
bmeyst
PostPosted: Mon May 16, 2005 6:03 pm    Post subject: Reply with quote
good queston!! sorry, no answer from me but i need the same info for my 97' zj!! i'll probobly be hauling a trailer alot now for work (glad to have that SHITE!! out of my truck though!!)
p.s. i have a "quadra-trac" transfer..
chrome don't get you home!!
PostPosted: Mon May 16, 2005 6:12 pm    Post subject: Reply with quote
I dont have a clue.. but keep in mind that a hitch is not the extent of a towing package ..You will both need transmission coolers as well..
You may already have the trans fluid running thru the radiator .. You will need to add a secondary out in front of the radiator..
U hual probobly has the hitch you want.. (Or a bone yard in the case of the 97..)
Good luck.
bmeyst
PostPosted: Mon May 23, 2005 4:09 am    Post subject: Reply with quote
thanks for the info! one more question, how can i tell if i have a tranny cooler or not and how difficult are they to install on a 97' quadratrac? appreciate it!!
