rear lap belt
diver8
PostPosted: Wed May 18, 2005 1:26 pm    Post subject: rear lap belt Reply with quote
Has anyone ever added a third seat belt in the back seat (lap belt)?
PostPosted: Thu May 19, 2005 12:54 pm    Post subject: Reply with quote
Do you plan on fitting 3 persons back there? Good luck, unless they're really tiny.
kitesurferinva
PostPosted: Fri May 20, 2005 9:12 am    Post subject: Reply with quote
You can do it by getting a set of lap belts from a CJ and using the stock mount brackets on the floor, just attach both ends. But like was mentioned, good luck fitting 3 people back there unless they are midgets...
Kitesurferinva -98 TJ 2" BB, 1" BL, Big Daddy Rocker Guards, Custom front bumper, SKBpro rear bumper w/ spare tire swing out carrier, 33x12.5 BFG MT's on 15x10 AR Outlaw II's, 2 Hella lights, warn engine and diff skids, Kilby steering skid
diver8
PostPosted: Fri May 20, 2005 10:02 am    Post subject: Reply with quote
Thanks...wanted it to center a child seat as opposed to having on one side. Just wanted to know if it was possible and safe.
Orng Beep
PostPosted: Fri May 20, 2005 10:24 am    Post subject: Reply with quote
I'm not sure what kind of jeep you have. I know in my TJ, there are anchors on the floor behind the back seat that you can hook a child seat. My son's seat has 2 anchor straps on the bottom of the seat that can slip through the seat and and 1 strap that goes over the seat. I hook the bottom straps, one on each anchor, and then pick a side for the top strap. It works well. If your Jeep does not have the anchors, It wouldn't be very hard to install some. Hope I helped.
(Disc. I am not a professional and my advice has only been aproved by me. I have not researched any regulations reguarding this matter. If you choose to use any of my ideas, consider them yours. Wink )
If Jeepin' is a disease, I hope they NEVER find a cure!
PostPosted: Fri May 20, 2005 4:57 pm    Post subject: Reply with quote
I would not put a child seat in the center using seat belts you've installed. On a TJ, the rear passenger side is the safest place for a car seat.
