Program Keyless Entry
03Overland
PostPosted: Thu Jun 16, 2005 7:15 am    Post subject: Program Keyless Entry Reply with quote
hello, i just bought a '03 JGC Overland, however the keyless entry needs to be programmed.
do any of you guys know what the steps are to program it?
02tj
PostPosted: Thu Jun 16, 2005 7:38 am    Post subject: Reply with quote
yep, stealer computer! had to do mine
03Overland
PostPosted: Thu Jun 16, 2005 8:06 am    Post subject: Reply with quote
Great! back to the Stealership.......
surely there is a way to DIY..... Confused
SecondZJ
PostPosted: Wed Jun 22, 2005 1:41 pm    Post subject: Reply with quote
try wjjeeps.com, I think there is a way, look in the tech bullitins
Doug
'97 Platinum ZJ ltd, I6 4.0, Quadratrac, 62mm TB, Hambek custom Hood, Kevins radiator Support, ADDCO Sway bars, Kolak Headlight Upgrade, Clear corners, front receiver, K&N FIPK II, 2"BB, OME stabilizer, trimmed front bumper cover
RussellRowell
PostPosted: Sat Aug 19, 2006 3:56 pm    Post subject: Reply with quote
Try This...Jeep keyless remote programming instructions:
- Sit inside the vehicle and close all the doors.
- Place ignition in the OFF position
- Open the driver's door and leave open during the programming procedure.
- Move the mechanical door lock lever to the LOCK position.
- Turn ignition to the RUN position.
- Aim the transmitter at the Keyless Entry receiver and press the Lock
button.
- Hold the button until the lights on the transmitter blink twice. The door
locks will cycle.
- Turn ignition off within 20 seconds.
- Check receiver memory by cycling door locks using the transmitter.
Up to four transmitters may be programmed into a vehicle.
Good Luck
1994 w327k
