Easy newby Q, Remove 5 speed shift stick in TJ?
roundhouse
PostPosted: Sat Jun 18, 2005 7:08 am    Post subject: Easy newby Q, Remove 5 speed shift stick in TJ? Reply with quote
Need to remove the stick from the tower in my 02 NV3550 trans, so I can install a boot below the stick.
The stick has a rubber isolator built in, and what appears to be set screws, only the set screws are threaded on the inside, so theres no way to use a hex wrench to loosen them.
whats the deal here?
I think the trans is from an 02, its going in a 74.
