ZJ Fuse block List...
PostPosted: Thu Jun 23, 2005 5:52 pm    Post subject: ZJ Fuse block List... Reply with quote
#1--20 amp---Power Ant. Tow Relay
#2--15 amp.---Brake lamps
#3--20 Amp---Hazard Lamps
#4--15 amp---Security Lamp
#5--15 amp---Interior lighting
#6--5 amp---Security alarm module
#7--15 amp---Security alarm relay , flash to pass
#8--15 amp---OVerhead console , Keyless entry radio memory clock chime module , power locks, power mirrors, hevac and VIC
#9--20amp--Rear wiper
#10--10amp---Radio Accesory
#11--15amp---Cigarette lighter
#12--15amp---Parking lamps, automatic headlights
#13--20amp---Horn Relay
#14--20amp---Power lock relay
#15--3amp---ABS Module and relay
#16--20amp---Turn signal
#17--7.5amp---Heater and air conditioner module
#18--15amp---Airbag module
#19--15amp---interior mirror,auto headlight,overhead console,VIC/GDM Module, Heated Rear window, illuminated entry and chime module
#20--10amp---Heated rear window switch, overdrive switch, speed control
#21--15amp---Security alarm module,Lamp outage module
#22--15amp---Airbag module, speedometer,tachometer, telltales and gauges
#23--15amp---Heated mirror feed,Heated rear window switch
#24--7.5amp---Instrument panel illumination
#25--30amp circuit breaker---Power seats
#26--30 amp circuit breaker---Power windows
#27--10 amp circuit breaker--Securty alarm module and front wiper
#28--30amp---Heated rear window relay
There you have it...
Now I am going to go and treat my writers cramp and carpal tunnel syndrome...
Mr. Green
PostPosted: Thu Jun 23, 2005 11:18 pm    Post subject: Reply with quote
very nice of you to post that thanks
