Swapping Scout axles into an XJ
Foxx
PostPosted: Fri Jun 24, 2005 11:22 am    Post subject: Swapping Scout axles into an XJ Reply with quote
Hey all. A buddy of mine recently offered me a set of axles out of an old IH Scout. If I recall correctly, the Scouts had Dana 44's front and rear, and are somewhat narrow.
My question is, how much work will be required to swap them in? I think the IH had a leaf spring up front, so I'll have to cut the perches off and add coil buckets, and probably relocate the rear perches, along with shock mounts.
Aside from that, can I expect these axles to have disc brakes on the front, or locking hubs? I'm not expecting them to, but I can hope. If they dont, are there any bolt on swaps to put discs on all four corners?
With four wheel discs, will I need to change out my master cylinder?
Last but not least, are the 44's an upgrade worth doing? I've heard the Grand Cherokee 44's have aluminum housings, which would suck.
Thanks
PostPosted: Fri Jun 24, 2005 1:12 pm    Post subject: Re: Swapping Scout axles into an XJ Reply with quote
Yes.
To my knowledge, they have manual hubs and I would guess, front disc/rear drum. Don't know if you could swap parts to get rear discs.
Make sure the front is driver's side drop. If not, it's not a working idea.
PostPosted: Fri Jun 24, 2005 7:36 pm    Post subject: Re: Swapping Scout axles into an XJ Reply with quote
No. I converted to rear disc last year and and am still running the stock master cylinder. The pedal is lower, but stopping power increased. However, the brake bias is slighty more rearward than I would like. An adjustable proportioning valve will fix that.
There are bolt on swaps...but they are expensive. A cheaper solution would be to do this: http://www.off-road.com/jeep/cherokee/2002/08_aug/reardisc/index.html
Foxx
PostPosted: Mon Jun 27, 2005 8:09 am    Post subject: Reply with quote
What if the front is passenger's side? I'm going to have to rotate the steering gear anyway for proper caster, so couldnt I just flip the axle 'upside down' and put the differential under the driver's side, and just re-weld everything?
PostPosted: Mon Jun 27, 2005 10:17 am    Post subject: Reply with quote
Can't do that - the rotation of the gears would cause the tires to turn backwards.
PostPosted: Mon Jun 27, 2005 1:30 pm    Post subject: Reply with quote
No. You can't. In addition the the gears running the wrong direction, you'd also have issues with proper lubrication. Center sections are designed to be run within a specific range of angles. Upside down is not one of them.
Foxx
PostPosted: Tue Jun 28, 2005 11:28 am    Post subject: Reply with quote
If everything works out, he may be doing me a huge favor. He said they were driver's side differential, and gave me a choice of gear ratio. I think the lowest was a 3.73.
With 31x 15.50 tires, what gear ratio do I want to keep around factory- spec fuel economy and power? I'm planning on gearing it maybe a little bit high if he doesnt have exactly what I need, because the XJ is currently my 'civilized' daily driver, so fuel economy would be good, and I also plan on doing some engine mods soon to boost power anyway.
So, how do I figure out what's in there now, and what I need?
Thanks
Foxx
PostPosted: Wed Jun 29, 2005 11:25 am    Post subject: Reply with quote
Alright, he told me that my choices are 308, 325, 350, and 373.
Which one would be closest to stock specs with 31's? I need to let him know tonight, so any help would be...helpful. Very Happy
Thanks
PostPosted: Wed Jun 29, 2005 11:48 am    Post subject: Reply with quote
http://jeephorizons.com/tech/rpmchart.html
