oil pressure drops at stops
r-dub
PostPosted: Tue Jun 14, 2005 12:28 pm    Post subject: oil pressure drops at stops Reply with quote
should I change the oil pressure sending unit or remove the oil pump and clean the screen?
thanks,
ron
Venomized
PostPosted: Sun Jul 03, 2005 7:00 pm    Post subject: Reply with quote
I would put a mechanical gauge on it and see if it really is loosing pressure first. I would also not drive it until you fuigure this out. If it really is loosing pressure then the outcome will be very expensive.
1998 ZJ, some stuff
2001 WJ, not much stuff
2005 Gulfstream Conquest LE, fun toy
nikon
PostPosted: Sun Jul 03, 2005 7:48 pm    Post subject: Reply with quote
how much is yours dropping. Funny you mention this because I just noticed mine doing the same thing coming back from the fireworks. Mine is usually holding strong at about 45-50 and i noticed today that at stops it would drop to about 30..... Confused
LISTEN TO BLACK SABBATH
FM2CDJC Member #10
9. Thou shalt not kill. Unless some motherf****r is coming into your house to take your s**t! - The Nuge
r-dub
PostPosted: Sun Jul 03, 2005 9:32 pm    Post subject: oil pressure drop Reply with quote
i recently fixed the oil pressure dropping problem. it was the oil pressure sending unit. its easy to change. you need a 1 1/16" deep socket to remove it. It is located right above the oil filter. part costs about 35 dollars.
thanks,
ron
