93 Grand Crerokee Laredo Cruise control doesn't work
Steve35897
PostPosted: Tue Jul 12, 2005 8:59 pm    Post subject: 93 Grand Crerokee Laredo Cruise control doesn't work Reply with quote
I just bought a 93 Grand Cherokee Laredo and the cruise control doesn't work. I don't have a check engine light.
Any help would be greatly appreciated.
Thanks
Steve
PostPosted: Tue Jul 12, 2005 10:23 pm    Post subject: Reply with quote
Check the vacum lines that come out of the fire wall on the passenger side (Tiny hard plastic lines..) and the ones that go under the battery..
They are not monitered by the computer..
Carl
95sahara
PostPosted: Wed Jul 13, 2005 4:12 am    Post subject: Reply with quote
Under the battery is a good place to look because the acid that leaks out of the battery runs down and build up on the battery tray, then eventually down past the tray and onto anything thats underneath it.
06 Rubicon
4" RC sus. lift, 1" PA BL
PICS
theskitzofrantic
PostPosted: Wed Jul 13, 2005 1:17 pm    Post subject: Reply with quote
I have a 97 Orvis that the cruise doesn't work on too. The cruise light in the dash comes on but it will not maintain speed.
Steve35897
PostPosted: Thu Jul 14, 2005 7:00 pm    Post subject: Reply with quote
I just checked the vacuum lines today. They seem to be fine. I unplugged the vacuum line from the servo I guess it is under the hood, then started the engine. There is good vacuum at the line when idling.
I also removed the switches from the streering wheel, they seem to be fine.
After finding nothing that seems to be wrong I cvontinued to try to get it to work while driving. I finally did but it seems really strange to me.
Does the cruise control work the way that most other cruise controls do?
With the On/Off switch On, I press the Set/Decel and the Resume/Accel simultaneously and the cruise starts to work. But it ocassionally stops working.
I haven't played with it enough to find out if pressing the resume after it stops working might restart it.
Does any of this sound familiar to anyone? Or does it just sound like a loose/ crossed connection somewhere?
Thanks
Steve
jeepjeepjeep
PostPosted: Sun Dec 04, 2005 8:46 pm    Post subject: Reply with quote
the broblem on my 93 was electronic in the srteering wheel whenever i turned too much it would shut off or not engage at all somethhing in the switch went bad so try that out
1993 jeep grand cheerokee
1994 jeep grand cheerokee wrecked
jekwone
PostPosted: Sun Jun 25, 2006 5:11 am    Post subject: Reply with quote
Steve...- I got the same issue going on.... did you resolve it? Any advice?
XTOZJ
PostPosted: Wed Jun 28, 2006 4:40 pm    Post subject: Reply with quote
After turning it on try just to push the Set button once and dont touch the Accel button at all and mine stays on......94 GLC.
It's a JEEP thing.... you wouldn't understand!
If it ain't a JEEP, its a wannabe!
Happy trails to you!
Whats in your holster?
