I need some help....dont we all
slamm36
PostPosted: Mon Jul 25, 2005 12:14 am    Post subject: I need some help....dont we all Reply with quote
OK Here i go
Im get erroe codes 12, 42(only after i replaced fuel pump assembly), 45, 45, and the closing 55. Right now im just gunna figure out the 2 45's. There is two possible causes for the 45 witch are either Trans Temp Sensor Voltage Too Low or Trans Temps Sensor Voltage Too High. Sence im getting two 45's im assuming that i have both proublums. 1st of it would be great if soem on could tell me if this is a sensor that i would be able to change ( i dont want to take the tranny apart). Then just about the time the check engin light came on i had no power while taking off, but i do have power once i get gowing. Too me it feals as if the tranny is starting off in 2nd. Could the sensor trick the comp on to soem how thinking some thing diffrent and not shifting back down to 1st. I am hopping it is just the sensor. Any insight would be great. Oh ya it in a 97 Gc 2wd with the 4.0. If u need more info plz ask. Oh ya 1 more thing is this a part that say carqwest would cary.
Thanks
