how to check engine codes... alternatives?
jc723
PostPosted: Thu Jul 28, 2005 5:21 pm    Post subject: how to check engine codes... alternatives? Reply with quote
are there any ways to check the engine codes if i dont have the plug in computer/scanner or however that thing its called?
Brad S
PostPosted: Fri Jul 29, 2005 9:20 pm    Post subject: Reply with quote
What year is your jeep? If it's.. 95 or older, you can do the 'key on/off' trick. Turn the key to power on-off, on-off, on-off, on
Should be three times, then your check engine light will blink your codes for you. long pauses between numbers.
let me know if you have any questions.
brad
PostPosted: Fri Jul 29, 2005 11:21 pm    Post subject: Reply with quote
It works on my 97 so it might work on yours also. Wink
http://www.jeephorizons.com/phpbb/viewtopic.php?t=2719
slamm36
PostPosted: Sat Jul 30, 2005 10:06 am    Post subject: Reply with quote
well at leat with my 96 and 97 it is alot easyer to read the codes because they are displayed on the digital odometer. This way u dont have to count flashes.
