wheel woble at speed with stock sups.
newzj97jeeper
PostPosted: Mon Aug 01, 2005 5:59 pm    Post subject: wheel woble at speed with stock sups. Reply with quote
when ever I am on the freeway whenever I get about 70-75 the wheel starts to wobble a little bit, I am not sure if this is the claimed death wobble since its not that bad, but the stearing wheel starts to vibrate and gets annoying as hell. I just put new tires on it and they should be balanced, could this be the rout of the problem or what?
keep it on the low end
PostPosted: Mon Aug 01, 2005 7:12 pm    Post subject: Reply with quote
It could be the balance, I'm not an expert or anything. Try checking your steering damper. I screwed up the stock one the first time I took my jeep out, didn't even do anything that extreme either. Basically all the fluid leaked out and I had to fight the steering wheel all the time. They are real easy to replace. I had to by a puller to get the press fitting out.
Its just a thought. If you haven't done any real off roading this probably isn't the problem.
newzj97jeeper
PostPosted: Mon Aug 01, 2005 8:25 pm    Post subject: Reply with quote
no unofrtantly no off road use yet. I will prob go get the tires balanced again just the be safe.
PostPosted: Tue Aug 02, 2005 1:31 am    Post subject: Reply with quote
Nope, that's not death wobble. You'll know when it's death wobble - you can barely control it and it feels like your death is imminent. Wink
I'd check to be sure that all the suspension components are tight, your bearings are good, you don't have any bent rims and the new tires aren't out of round. Oh yeah, slow down. Mr. Green
newzj97jeeper
PostPosted: Wed Aug 03, 2005 7:31 am    Post subject: Reply with quote
as anyone who lives in the bay area knows if you driver 65 your likely to end up on the nightly news for being ran over,
PostPosted: Wed Aug 03, 2005 10:53 pm    Post subject: Reply with quote
If only I had a dime (adjusted for inflation, of course) for every time I've heard that line.
newzj97jeeper
PostPosted: Sun Aug 07, 2005 9:36 pm    Post subject: Reply with quote
I found out what was wrong. when I got new tires put on the dumbass put the wrong weights on and they fell off. so far its only the drivers side so I took care of that and now rides like it should.
Bill 705
PostPosted: Fri Nov 18, 2005 6:01 pm    Post subject: Reply with quote
I thought death wobble was only on YJ's!
PostPosted: Sun Nov 20, 2005 6:30 am    Post subject: Reply with quote
You have never experienced death wobble till you have a full coil sprung vehicle with 6" of lift and 35" tires start shaking under you...
I was sitting 2" higher up in my seat be the time I slowed down and got it under control... (Trackbar bolt broke....)
YOu will never mistake death wobble for anything once you experience it...
And if you lift your Jeep .. You probobly will experience it... But its normally easily curtailed and you can go about your life..
Then you can tell your horrible death wobble stories... rofl rofl
PostPosted: Sun Nov 20, 2005 12:22 pm    Post subject: Reply with quote
After you clean out your pants. rofl
