OILY Oil pan and Transmission Belt Housing on 01 TJ
kchan156
PostPosted: Mon Aug 01, 2005 6:57 pm    Post subject: OILY Oil pan and Transmission Belt Housing on 01 TJ Reply with quote
Hi everyone again. I'm almost about to take the plunge on this 01 TJ with 21,000 miles. We took it to CSAA for an inspection and they found that the the rear end of the oil pan and transmission belt housing is oily.
Could this being from the Jeep been sitting there for the past two years with just 2,000 miles? They recommended to clean the oil and see if it leaks. Should I hold off on the purchase or what so I do? Thanks!
WhatWasIThinkin
PostPosted: Tue Aug 02, 2005 3:09 am    Post subject: Reply with quote
Oil back there can be from a rear main seal leak. It seems that whoever puts these together at DC has been doing it wrong from years. Both my TJ's started showing signs of oil back there after @ 3000 miles....and it also seems that many others go threw this. Ive heard many times that even after being repaired under warrentee, that it still continues to be a problem. My current TJ did this, but it appears that it has stopped for the moment.
Real Jeeps dont wear Bra's
03TJX
PostPosted: Thu Oct 27, 2005 12:40 pm    Post subject: Reply with quote
I have found oil there on my Jeep but only after an oil change. So one day we took it to my dads shop and put it up on the rack and did an oil change and it seems that some of the oil that comes from the filter when you remove it runs right down through that are also. Have cleaned it off and driven about 5000 miles and no new signs of oil. A possibility. But the rear mains are not noted for lasting too long.
JEEP= Just Empty Every Pocket
If opportunity doens't knock, build a door
2003 TJ "X", 4.5" RE SuperFlex Lift
Tom Woods Drive Shaft, Advance Adapters SYE, 33x12.50x15 Interco TrXus MT on 15x10 Aluminum Wheels, Jeeperman Rear Bumper&Tire Carrier
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
