Question about cherokee
Rafa
PostPosted: Mon Aug 01, 2005 7:25 pm    Post subject: Question about cherokee Reply with quote
Hi, nice forum, I happy found this site..!
A few days ago I bought a Cherokee 1976 with a 360 V8 enginee.
I read in other websites that the car has a rear and from DANA 44, thatīs true?? Rolling Eyes
And with those diferentials what is the biggest tires i can use?? 35 inches? 38??
I really dont know.. thanks a lot for your help Mr. Green Smile
PostPosted: Mon Aug 01, 2005 7:36 pm    Post subject: Reply with quote
Welcome. Technically what you've got there is a Wagoneer. The Jeep Cherokee that was built from 1974-1983 was a model SJ. The 1984-2001 models are designated XJ. Wink
It's possible that it has 44's front and rear. If it does, you could get 35's or even 38's on them. I would do some upgrades to beef up those axles first though.
PostPosted: Tue Aug 02, 2005 1:27 am    Post subject: Reply with quote
Yep, if they're the stock axles, they should both be Dana 44's.
Rafa
PostPosted: Tue Aug 02, 2005 11:12 am    Post subject: Reply with quote
Thanks a lot for your replys..!
So, a 38 inches tires will be nice!! hehe..
And what about the engine? is a good engine? any of you know de specs?
Is a really fast car... and really like it..! Its a new proyect and hope everything goes fine!
Do you have pictures of a modified wagoneer?
PostPosted: Tue Aug 02, 2005 11:29 am    Post subject: Reply with quote
Well, it's not a car, but that engine was rated at 195 HP@ 4400 RPM 295 ft/lbs torque @ 2900 RPM - not a rocket sled, but it'll work. You'll probably have to do some trimming to get tires that big to fit as well as regear the axles to regain your acceleration. Try searching around on the web for some photos. Wink
PostPosted: Tue Aug 02, 2005 7:46 pm    Post subject: Reply with quote
6 inch lift will let you fit 35s with no prob.....they did it on trucks
jeepmanmike
PostPosted: Thu Dec 08, 2005 3:40 pm    Post subject: the right forum Reply with quote
go check out the international fullsize jeep club do a search and it will come up its the best place u can go for the fullsize stuff im a member and have been since 1997
