WJ transfer case into a ZJ????
nixt
PostPosted: Wed Aug 17, 2005 6:30 pm    Post subject: WJ transfer case into a ZJ???? Reply with quote
I am blowing about $200 a week on premium gas so I think 2wd would help quite a bit. Therefore, a few more questions: If I swap in a 242 will I lose my "Low-Lock" capability? My local shop manager is convinced that I have a center diff instead of a viscous coupling- I believe that the 242 does not so I am assuming I would loose the lock in that. If the WJ 242 is not an exact swap- what year/model is? I am on a budget since gas is so damned expensive and I would like to make this as painless as possible.
Repeat of my earlier post:
I have a 98 ZJ 5.9 with the 249, can I swap in a 242 "HD" from a WJ? I am not familiar with the WJ's 242 does it have the regular 2high, 4lo, 4hi part time, and 4hi full time? Will I have to buy new driveshafts?
PostPosted: Thu Aug 18, 2005 9:11 am    Post subject: Reply with quote
The only way to tell if it will fit is to put them side by side and measure the input gear..
The 242 does lock in 4 part time and in 4 low..
YOu shouldnt need new drive shafts ..
