A/C Evaporator Drains Into Interior - A bit more complicated
Brad S
PostPosted: Fri Aug 19, 2005 10:11 am    Post subject: A/C Evaporator Drains Into Interior - A bit more complicated Reply with quote
Alright, I've seen this problem posted on message boards all over the place.. Same 'answer' everywhere you go: "Drill hole in evap. housing, unclog drain tube and then plug it."
I have done that, I fed a wire through the hole but water still runs into the interior after I plugged it. After looking closer, it appears be coming from the back of that housing unit.. it almost feels like a piece of foam back there..
So, what does this mean? did the tube come off of the housing unit?
Thats the only thing I can think of, but how in the name of Zues's butthole do you get to that hose? I mean, there is absolutely nowhere that I can see outside the vehicle, wheel well, engine compartment, undercarage, anywhere to get to that tube!
Has anyone else ran into this? I've read many times that people end up spending a couple $1000 on this problem, and that is one thing I can't do.
Help anyone??
PostPosted: Mon Aug 22, 2005 3:43 pm    Post subject: Reply with quote
Got me on this one.. I have taken my AC out...
Brad S
PostPosted: Sat Aug 27, 2005 6:10 pm    Post subject: Reply with quote
well, the only thing i can figure is that dirt just keeps re-clogging it.. darned AC..
