Tire Clearance Question
RustyBrown
PostPosted: Sun Sep 04, 2005 6:17 am    Post subject: Tire Clearance Question Reply with quote
Hey Guys,
Just a simple question. I have just installed a new set of wheels and tires to my 99'. They are 31 12.50 pro-comp x-terrains on weld racing sidewiner wheels. I also have Bushwacker 4" flares. I don't have as much clearance as I like and I was wondering wat I should go with to lift it a little. I would prefer not to use a body lift. Ho High should I go? a 2.5 lift or some spacers of some kind?
Keithtj
ARLI$$
ARLI$$
PostPosted: Sun Sep 04, 2005 9:59 am    Post subject: Reply with quote
a stock tj will handle the 31's, but if you want a mild lift for a little money, I would go with the Rubicon Express 2" budget boost. If you want a full suspension lift, then I would go with Old Man Emu's 2.5" lift.
My Morning Jacket
RustyBrown
PostPosted: Sun Sep 04, 2005 1:55 pm    Post subject: Reply with quote
whenever I hit a bump with my tires they rub on the fenders I need just a bit of lift
PostPosted: Sun Sep 04, 2005 4:07 pm    Post subject: Reply with quote
That's because they're 12.5" wide. 31x10.5s tuck nicely. Adding more suspension lift isn't going to fix the problem unless you adjust your bumpstop length to keep the tires from pushing up into the fenders. A 1" body lift will provide 1" more tire clearance and would be the easiest way to accomplish what you want to do without sacrificing upward travel of the suspension.
RustyBrown
PostPosted: Mon Sep 05, 2005 10:30 am    Post subject: Reply with quote
The back spacing on my wheels provide me with all the steering room I need. What I was trying to say is that when I hit a bump my tires rub the flare so the Issue is verticle clearance
RustyBrown
PostPosted: Mon Sep 05, 2005 12:46 pm    Post subject: Reply with quote
I have been comparing the fabtech 2.5 and the arb 2.5. What would be the benefit of installing new coil springs versus putting in spacers. Which would you recomend?
PostPosted: Mon Sep 05, 2005 2:02 pm    Post subject: Reply with quote
You're mixing up my statements. I was not talking about horizontal clearance between the tire and suspension components. I was talking about vertical clearance. And I was telling you that unless you lengthen your bumpstops, all the suspension lift in the world isn't going to keep you from rubbing the flares upon compression. Suspension lifts do not provide tire clearance, body lifts do. A 1" or taller body lift would provide you the clearance you need to prevent tires from rubbing the flares. Either that or lengthen your bumpstops to limit upward travel of the suspension.
RustyBrown
PostPosted: Tue Sep 06, 2005 5:08 pm    Post subject: Reply with quote
sorry i didn't read your post correctly, my mistake, I know exactly what you are talking about I just wasn;t thinking. I don't want to extend my bump stops without lifting because I would like to have the extra travel. Would you go with the ome 2.5 or fabtech? I am leaning towards ome because I like the idea of new springs rather than spacers. What do you think?
PostPosted: Tue Sep 06, 2005 5:14 pm    Post subject: Reply with quote
Given those two options, your only choice is the OME. Coupled with their shocks, it's one of the best kits out there in their height range. Contact Dirk at DPGOffroad for the best service and information in regards to OME products.
See www.dpgoffroad.com
