Replacing transfer case fluids
Keithtj
ARLI$$
ARLI$$
PostPosted: Sat Oct 01, 2005 1:43 pm    Post subject: Replacing transfer case fluids Reply with quote
What's the best way to do this? REmove the skid plate and drain the fluid and the refill it from the rear of the t-case?
My Morning Jacket
WhatWasIThinkin
PostPosted: Sat Oct 01, 2005 2:44 pm    Post subject: Reply with quote
Thats one way.
If you want to make it easier on yourself try this. You wont have to remove the skid.
If you dont allready have one, pick up a fluid sucker from any auto parts place. Remove the threaded fill plug and use the fluid sucker to pull out as much as you can.
A large cookie sheet pan comes in handy for the next part. By now you should have most of the old fluid out. Keep a oil catch pan handy too. Lay the cookie pan on the skid and remove the threaded drain plug. If your carefull you can tip it so that the rest of the fluid will run down it into the oil catch pan.
After all the oil is out, clean the threads on the plugs and use a high end teflon tape and/or thread sealant. Install the drain one and fill the oil back up where it should be, install fill plug and your done.
Real Jeeps dont wear Bra's
KnightFire
PostPosted: Sat Oct 01, 2005 2:45 pm    Post subject: Reply with quote
That's the only way I saw how to do it, when I was under there changing trannie fluid last weekend. I haven't done the TC yet, but the method you describe is most likely how I'll do it.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
Keithtj
ARLI$$
ARLI$$
PostPosted: Sat Oct 01, 2005 2:56 pm    Post subject: Reply with quote
I can't find the drain plugs on the underside of the t-case, I know its there, but don't know exactley the location.
My Morning Jacket
CoreyXJ
Turkish
Turkish
PostPosted: Sat Oct 01, 2005 4:45 pm    Post subject: Reply with quote
See the black caps (they cover the drain holes) the one under the ID tag is the fill hole and the one to the far left is the drain hole. Take the fill plug out before you take the drain plug out. This will prevent the fluid from glug-glug-gluging..... Ya dig?
Keithtj
ARLI$$
ARLI$$
PostPosted: Sat Oct 01, 2005 7:02 pm    Post subject: Reply with quote
ok, well for some eason I thought you mean't under the t-case, like on the bottomside of it. That's why it was confusing me. Gotcha!
My Morning Jacket
