Leaking D35
Goto page 1, 2  Next
KnightFire
PostPosted: Fri Sep 23, 2005 3:47 pm    Post subject: Leaking D35 Reply with quote
Well, I've noticed that after my RTV job a few months ago, I had a slow but steady leak in the D35. So, I said the hell with it and bought some lube locker gaskets and did the job over again.
The problem? The damn thing is leaking faster now than it was before!!! I used a razor blade, thuroughly cleand the RTV off both mating surfaces, torqued the bolts down and it's leaking like a sieve!
Can anyone offer any suggestions?!?! I got mad after 4 hrs and quit, needed to cool off before I took my hammer to the body of the Jeep, lol.
So does anyone have any suggestions? I'm going to buy a torque wrench to ensure the bolts are properly torqued down...other than that, I don't have a clue why it's leaking...
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
quadna71
PostPosted: Fri Sep 23, 2005 5:29 pm    Post subject: Reply with quote
either buy a new OEM cover (dime a dozen) or pony up for a nice crane or BTF cover. better quality and bucco protection to boot!
chris (are you letting it "skin" up before installing?)
2003 TJ Sport
KnightFire
PostPosted: Fri Sep 23, 2005 5:39 pm    Post subject: Reply with quote
I have poison spyder diff covers on there already...so you think the cover is tweaked? I haven't banged it at all...no sign of warpage...what do you mean by skin up? I didn't use RTV this time, just a gasket.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
WhatWasIThinkin
PostPosted: Fri Sep 23, 2005 6:37 pm    Post subject: Reply with quote
allowing it to skin means to let it air dry a bit so that the rtv dries a little.
Ive never used the gaskets, just ultra copper rtv on both mounting surfaces and skin over like Chris says. When allowed to skin, the rtv wont squish out as easily as it does when wet. Also dont over do the rtv either....too much can be a problem too.
After putting the diff cover on and snuggling the bolts down as even as you can, allow the rtv to dry for a few hours before adding gear oil.
Real Jeeps dont wear Bra's
KnightFire
PostPosted: Fri Sep 23, 2005 7:37 pm    Post subject: Reply with quote
So your thinking I should give the RTV another shot and lose the lube locker gasket?
I did let it dry a bit last time before mounting and adding fluid, but I didn't apply it to both mating surfaces, just the cover.
The thing is, it is REAL hard not to slide the cover around during install with the diff. gaurd on it, basically you have to hold the cover and the gaurd over top of the cover while trying to get a bolt in with one hand...I think that was why I had a small leak last time, it had smeared a bit.
Would it be a terrible idea to use the RTV WITH the gasket?
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
WhatWasIThinkin
PostPosted: Sat Sep 24, 2005 4:13 am    Post subject: Reply with quote
KnightFire wrote:
So your thinking I should give the RTV another shot and lose the lube locker gasket? Ive done this many times myself....no gasket just make sure the surfaces are clean..this is a must and for years Ive used the copper based rtv without failure. Ive heard good things about the lube locker gaskets, but sounds like in this case it isnt working as intended.
I did let it dry a bit last time before mounting and adding fluid, but I didn't apply it to both mating surfaces, just the cover.Yup apply to both surfaces....a thin even coat as best you can anyway. you dont want more than @1mm thick on either surface...too thick dosnet help and just makes a mess.
The thing is, it is REAL hard not to slide the cover around during install with the diff. gaurd on it, basically you have to hold the cover and the gaurd over top of the cover while trying to get a bolt in with one hand...I think that was why I had a small leak last time, it had smeared a bit.Allowing the skin to form will help with this. Does your guard go over the stock cover? Any like that Ive seen dont use the top bolts, so maybe get a few of the upper ones started first. Snug all the bolts a little to start. I like to do a star pattern when I tighten, simular to wheel lug nuts and dont over tighten any of them. If memory serves me the torque on them is only @15-20 ft.lbs, so fairly light. Ive never used a torque wrench on them, but just tightened them up by feel.
Would it be a terrible idea to use the RTV WITH the gasket?If you mean use rtv with the Lube Locker, then yes its a bad idea. The Lube locker gasket is siliconed based and using rtv silicone will cause instant failure with any Ive seen. Ive never used the Lube Locker brand, but any silicone gasket Ive ever used either was marked to not use silicone sealants or had a note on the box etc. Ever one Ive used was meant to be used dry.
KnightFire
PostPosted: Sat Sep 24, 2005 5:42 am    Post subject: Reply with quote
Yes
Get two 3-4" long bolts that will thread into the holes for the cover bolts. Cut the heads off. Thread these pegs into two holes on the differential. I use two at the top of the sides before it starts to curve in at the top. Goop up the cover, let it set up, slide it over the pegs. Install the remainder of the bolts, remove the pegs, reinstall bolts in holes pegs were it. Final torque all the bolts.
I've used RTV and a paper gasket to solve a leaking problem I was having. After every wheeling trip, I'd have a leak in one or both diffs and would need to reseal them. I went to an RTV/paper gasket/RTV layered setup and haven't had a problem since.
KnightFire
PostPosted: Sat Sep 24, 2005 4:12 pm    Post subject: Reply with quote
Thanks for the advice guys, I'm going to ditch the gasket and try the RTV again, only this time I'll use your tips.
I'm also going to put the cover on without the diff gaurd, that will make it easier (they use all the bolt holes). Then I'll wait a week or so and put the gaurds back on.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
KnightFire
PostPosted: Sun Sep 25, 2005 11:04 am    Post subject: Reply with quote
Worked like a champ, I used RTV again, but this time I didn't try to put on the diff. gaurd with the cover. I'll put the gaurd on next weekend once the RTV is nice and set.
I did notice that my front diff is leaking a bit too (sigh)...so I guess I'll be tackling the front next weekend as well.
Thanks for all the suggestions!
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
mucker111
PostPosted: Mon Oct 03, 2005 6:20 am    Post subject: Reply with quote
[quote="WhatWasIThinkin"][quote="KnightFire"]
KnightFire, you sure you don't mean a 1cm coating?
my creditcard is 1mm thick!
KnightFire
PostPosted: Thu Oct 06, 2005 12:16 am    Post subject: Reply with quote
[quote="mucker111"][quote="WhatWasIThinkin"]
Actually thats a quote from WhatWasIThinkin' Smile
But to answer your question, I definitely used more than 1mm of RTV, LOL. I think part of the problem last time was that I was too minimalistic...this time I put on a HEALTHY bead, worked like a champ.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
WhatWasIThinkin
PostPosted: Thu Oct 06, 2005 3:11 am    Post subject: Reply with quote
1cm thick? Shocked to both surfaces? shock
thats almost an inch of rtv schpoo.......that would be a bit much. Wink
1mm thick is okay as long as its applies to both mating surfaces. Not just a 1mm bead...that wouldnt be enough.
KnightFire
PostPosted: Thu Oct 06, 2005 2:44 pm    Post subject: Reply with quote
Nope, couldn't reach the diff. entirely to put a bead all the way around, so I just put a healthy bead on the diff. cover.
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
WhatWasIThinkin
PostPosted: Thu Oct 06, 2005 6:40 pm    Post subject: Reply with quote
Yeah thats something I forgot about untill you mentioned it.
How to get to the diff? Its tight in there.
I used my DangerJack2000 aka...the highlift and raised the body up high enough so that I could get at the diff easier.
PostPosted: Thu Oct 06, 2005 7:16 pm    Post subject: Reply with quote
I jack it up, put standjacks at the frame and drop the axle. On both our Jeeps that usually gives plenty of clearance (from the gas tank) to get in there and work.
My $0.02
Goto page 1, 2  Next
Page 1 of 2
