question about a driveshaft
jeepzj9304
PostPosted: Sat Oct 15, 2005 10:21 pm    Post subject: question about a driveshaft Reply with quote
i have a 3inch bb in the front and a 2 inch in the rear, now i am wanting to put a 3inch coils on top of that, i know every thing i need to do with the susp to make it work its just the drive shaft that has me confused. i dont want to get a TC drop due to the fact it decreases my break over angle. and if i need a cv driveshaft where can i get one cause i been searching and i cant find anything.
93 ZJ 4.0 I6
K&N insert
3" front BB
2" rear BB
31x11.5" Mickey Thompson Baja Claws
16"x10" 4.25 Backspacing Rockcrawler Rims
PostPosted: Sun Oct 16, 2005 9:24 am    Post subject: Reply with quote
Did you check Tom Wood's? http://www.4xshaft.com/
edit: what transfer case do you have and do you have an SYE?
jeepzj9304
PostPosted: Sun Oct 16, 2005 10:24 am    Post subject: Reply with quote
i have the 242 tc and no sye
93 ZJ 4.0 I6
K&N insert
3" front BB
2" rear BB
PostPosted: Sun Oct 16, 2005 6:35 pm    Post subject: Reply with quote
I am running RE 5.5 springs and stock shafts.. If anything with that much lift you are going to have to push your axle back because it will swing in and make your shaft to long....(no pun intended.. Mr. Green )
Other than that you should be fine..
