back spacing
grandjeeper
PostPosted: Tue Oct 18, 2005 4:53 pm    Post subject: back spacing Reply with quote
any body know what the back spacing need for a 2inch lift. and also for a 3 or 3.5 inch lift
93 jeep grand cherokee 4.0 I6, 2inch spacer lift, 31 BFG AT,
S
PostPosted: Tue Oct 18, 2005 9:50 pm    Post subject: Reply with quote
I take it you're talking about wheel backspacing. According to the recommendation from Kevin's Offroad website you want 4.5" backspacing with a minimum of 4.0" on a 2" lift. A 4.25" to 3.75" for 3.5" lift. Or go to Kevin's website if you need further information and he'll break it down from 2" to 8" lifts.
PostPosted: Wed Oct 19, 2005 9:56 am    Post subject: Reply with quote
im at 3.5 inch lift and running factory jeep wheels....there backspacing is under 4.0 if i remeber correctly...and my wheels dont rub
grandjeeper
PostPosted: Wed Oct 19, 2005 6:00 pm    Post subject: Reply with quote
kool, my front does a little, but i was just wanderin what they recommend
PostPosted: Wed Oct 19, 2005 6:34 pm    Post subject: Reply with quote
i also have another inch and a half on you tho....
PostPosted: Wed Oct 19, 2005 8:04 pm    Post subject: Reply with quote
The backspacing has nothing to do with your lift.. IE if you where running 14" of lift and stock tires...Stock rims and back spacing would be fine...
But if you want to go to Say.. 33X12.5 You will need at least 4" backspacing...
I Personally am running 3.75 with 35 X12.5 tires.. The backspacing on the rim is to allow wider tires to clear at full lock (turned all the way.) without rubbing... So its not dependent on lift its dependent on tire...
WIth 3.5 " of lift I think you could clear 31X10.5 stock rims should be fine.. But if you are going to buy rims go ahead and get the 4" backspacing so that when you decide to go with bigger tires you can...
Also keep in mind that more backspacing on your rims will put more pressure on your unit bearing causing them to wear faster...
Hope that helps..
Carl
grandjeeper
PostPosted: Fri Oct 21, 2005 4:04 pm    Post subject: Reply with quote
my front tires rub alittle, i have a 2 inch lift now and i wont be adding any more till summer. would i be fine with 4inch of backspacing for the 2 ich. and then when i get the rest ( net will be 3.5) will that be suffacent with 33x12.50 or x 10.50.
PostPosted: Fri Oct 21, 2005 7:05 pm    Post subject: Reply with quote
Yup..You would be fine for 33x12.5
grandjeeper
PostPosted: Sat Oct 22, 2005 1:11 pm    Post subject: Reply with quote
kool, thanx again Swampy
