Outer U-joints on front differential in my 91 XJ
luvthatsound40
PostPosted: Sat Oct 08, 2005 1:24 am    Post subject: Outer U-joints on front differential in my 91 XJ Reply with quote
Last night while changing the front brake pads I happened to notice that my drivers side outer u-joing has play in it and it's time to replace it. Anybody ever replace thiers , and what's involved in it?
Thanks
luvthatsound40
PostPosted: Sat Oct 22, 2005 3:24 am    Post subject: outter u- joint in front differential Reply with quote
I decieded to take it to the dealer and had them fix it. I have an 1,100 mile trip ahead of me this morning and I was running out of time. A $275.00 fix.
PostPosted: Sat Oct 22, 2005 5:33 am    Post subject: Re: outter u- joint in front differential Reply with quote
luvthatsound40 wrote:
A $275.00 fix.
Shocked
You realize that's like a $20 part.
badger
PostPosted: Sat Oct 22, 2005 7:11 am    Post subject: Reply with quote
ya but when you are also paying their guy some 50 to 60 an hour to work on it it adds up fast.not that i would pay somebody to put in an axle joint but 240 is about right from a dealer.
One Built XJ
PostPosted: Sat Oct 22, 2005 7:42 am    Post subject: Reply with quote
Changing one side can be done in an hour, especially for a shop that can work faster than your average Joe. Now, I don't know what book rate is for this...but stay away from the dealer if you need repairs. They don't call them the stealer for no good reason.
Onkover
PostPosted: Wed Oct 26, 2005 7:25 pm    Post subject: Reply with quote
What is involved?
Take off tire
remove brakes
unbolt bearing/hub
With BFH pull out axle
Using a vice, socket and BFH pound out one side of joint
take off caps and remove joint
install new joint with some grease and do eveything in reverse.
Just to give you a rough idea
www.4x4trailhunters.com
luvthatsound40
PostPosted: Sun Oct 30, 2005 2:39 am    Post subject: Re: outter u- joint in front differential Reply with quote
A $275.00 fix.
Shocked
I moved from MA to SC and needed to get it done right away. I towed my boat down here with it, and also loaded to the inside roof front to back. I don't remember what the dealer charged me for the part, but the labor was 70 bucks an hour. I usually do all the work on it myself to try to save money, but in this case it's something I just had to do.. Sad I made it down here in about 16 hours of non-stop driving with no problems at all.
