CJ 350 Need Help
TampaCJ5350
PostPosted: Fri Oct 28, 2005 6:09 pm    Post subject: CJ 350 Need Help Reply with quote
I have a 81 Cj5 with a chevy 350, hear is the problem if any one can help, the motor ran great until I attempted to install fenderwell headers, not realizing the roll cage had being modified they did not fit, in the process , I removed the coil, ignition switch, and, cap and rotor, I have since reinstalled all this and now all I get in the motor barley wanteing to turn over like it is struggling, any ideas , thanks alot!
Bockwinkle
PostPosted: Tue Nov 15, 2005 6:03 am    Post subject: did you check Reply with quote
that you didn't disconnnect or partially disconnect or damage the grounding strap or starter motor wire? I assume you checked your battery for juice.
Bockwinkle
84 CJ-7
