No Bus
markm
PostPosted: Sun Nov 20, 2005 3:25 pm    Post subject: No Bus Reply with quote
I own a 2000 Wrangler. I have occassions where the check engine light will come on, the air bag light will come on, and the tach and speedometer will shut down and it says No Bus in the ditital odometer. Bus is a computer term but what does No Bus mean?
WhatWasIThinkin
PostPosted: Sun Nov 20, 2005 5:06 pm    Post subject: Reply with quote
Im not sure what the no bus this means, but Im sure that your contacts behind the dash have gotten dirty or maybe corroded. This will cause the same symptoms that you have. Not always, but ussually happens to Jeeps that are left topless and are subjected to the elements.
One quick fix.....banging on the top of the dash will sometimes be a fix. But if this is the real problem, taking the dash apart and cleaning the wire conection and dielectric grease sealing them is the best cure.
Real Jeeps dont wear Bra's
oldjeepman
PostPosted: Mon Dec 26, 2005 8:47 pm    Post subject: no bus Reply with quote
hey my 99 also had no bus on it and the dealer replaced the dash wiring harness on it ,but i was also still under warranty at the time.
99TJ
PostPosted: Wed Dec 28, 2005 1:25 pm    Post subject: Reply with quote
"No Bus" is just the gauge cluster telling you that it is not receiving the parallel data bus from the computer, because the connection has come loose.
This is a common problem with the earlier TJs. Jeep was supposed to have fixed it in recent models. I have to pull my gauge cluster out and re-seat it about once or twice a year because of this problem. It usually comes loose when the weather changes from summer to winter.
