BIG BATTERY PROBLEM! Help please!
coolest_stan
PostPosted: Tue Jan 10, 2006 12:52 pm    Post subject: BIG BATTERY PROBLEM! Help please! Reply with quote
well heres what happened. My battery is fine one day, so Im drivign around. I turn off the engine, come back outside 5 minutes later, and the car wont even start. WHen I turn the ignition NOTHING happens at all. Like the car is dead. SO then I get my uncle to jumpstart it and and it works. Wellt he next morning, I have to get it jumpstarted again, and thenI drive it to autozone. I take out the battery, and the guy at autozone checks it in his little machine. He says its FINE! 14 volts!
he tells me maybe the connectors are dirty.
So I go back outside and put the battery back in, and kind of wipe the connectors with my hands a little (they look real clean, no corrosion).
And the car gets the eletricity!!!
SO I think everything is fine, and eveyrthing works for a day
THen the next day, I turn on the car to go to school, and the idel is really rough. I jsut ignore it and drive to school. WHen school is out, I get in my car to go home, and NOTHIGN HAPPENS! Like before, it seems liek the batteyr is dead. The door lights don;t even come on!!!
THen I get a friend to jump me, and the car starts.
What is going on!!!!!!!!!!!!!!!!!!!!!
i just cleaned the battery teminals, didnt do much. Here is the latest series of events:
I clean the terminals and connectors off, replace the battery connectors onto the terminals. The car gets electrcity! 9I can tell because the security system automatically turns on).
SO I shut off the security system and I go to start the car. ANd immediately everything dies.
WHen I go back to the batteyr and wiggle it around, the security system will start up again, and then when I go try to start the car again, it dies immediately... again.
So whats going on!!!! bad starter maybe? Do i need completely new terminals?(the ones i have now are kind of loose and still have corrosion over them)
can't be a bad battery or alternator (I measured it 12.6 volts).
coolest_stan
PostPosted: Tue Jan 10, 2006 12:52 pm    Post subject: Reply with quote
update:
i posted on another forum and they think its the cables or eithe rthe battery has a dead cell.
anyway to check for a dead cell, and how would I replace the cables of my battery? Could I do it myself? and what toosl would I need?
PostPosted: Tue Jan 10, 2006 1:27 pm    Post subject: Reply with quote
I was going to ask if you'd checked the cables too. Yes, you can get a hydrometer at the parts store to check the cells of the battery. Also you mentioned that the terminals are corroded. Clean them thoroughly. Wink
coolest_stan
PostPosted: Tue Jan 10, 2006 6:31 pm    Post subject: Reply with quote
so you don't think i need new cables? I actualyl think its the battery now, because when I put a "load' on it, i.e try to start my car, it just dies. SOunds like a dead cell to me....
what do you guys think
PostPosted: Tue Jan 10, 2006 7:27 pm    Post subject: Reply with quote
No, I'm saying if I were you, I'd check your cables. Wink
PostPosted: Tue Jan 10, 2006 8:07 pm    Post subject: Reply with quote
Yup.. I am thinking cables... Mr. Green
coolest_stan
PostPosted: Tue Jan 10, 2006 8:35 pm    Post subject: Reply with quote
ok cool.... i bet the cables are the problem!
Now the problem is, I don't kno whow to "check" if the cabvles are wrong. I looked for lumps but it is too hard to tell (there is tape around al the wires and crap)
how would I replace the cables anyways? WOuld I have to rerun the cales thorughout the entire car?
I am thinking about just changing the battery connectors and seeing if that will help. (can I change the battery conenctors myself? and what tools will I need? and any recommendations on waht kind of batery connectors to get)
coolest_stan
PostPosted: Wed Jan 11, 2006 9:26 pm    Post subject: Reply with quote
alright, heres the rpoblem with replacing the cables. There are two cables leading to each terminal!
each terminal has a cable that looks liek it will be very easy to replace ( one of the negative ones goes directly to the chassis and one of the positive ones goes directly to a box (the starter I think)). However, the second cables are oens that go into the interior of the jeep! Can I jsut replace the ones that lead to the starter and chassis?
(the third cable is just the power calbe leading to my subwoofers)
