Correct Nuts & Bolts?
DIGITRUCK
PostPosted: Thu Jan 12, 2006 2:50 pm    Post subject: Correct Nuts & Bolts? Reply with quote
Hey,
'88 XJ Cherokee Laredo 4.0L Auto 4WD.
I just received some Nuts & Bolts for the Upper Control Arms and wanted to know if they are the correct ones.
1. One of the Bolts is around 3-1/4" Long. The Head is Flat Round with a Torx in it. I have the matching nut for the threaded portion.
2. The other Bolt is longer, around 3-3/4" Long. The Head is Hex Nut with a weird looking "washer" attached. This "washer" is teardrop shaped with the bottom cutoff. You'll know what I mean if you're looking at it.
And I have the matching nut for the threaded portion.
Thx, Phil Smile
PostPosted: Thu Jan 12, 2006 6:07 pm    Post subject: Reply with quote
Sounds like it.
