Please help... 4wd-low only works
covered
PostPosted: Sat Jan 14, 2006 9:53 am    Post subject: Please help... 4wd-low only works Reply with quote
I have a 92 wrangler 4cyl. and I was driving on the highway the other day. I heard a loud bang noise after a hit a small bump in the highway. I pulled over because I thought it was my u-joints .. I looked underneath and everything was fine. I starting to drive the Jeep again and then about 100 feet after starting to move the jeep went into neutral... .. Now this is weird.. I could shift into any gear without the cluth being used when the jeep was in 2 wd but the trasmission would work internally but the jeep would not move and was like it was stuck in neutral.. I could hear the gear turning in the trasmisssion when i worked through the gears.. so I thought is was the transmission. SO just to try it.... I put the Jeep in 4wd low and the Jeep shifted right and moved. I could not believe it ..Now the jeep only works in 4wd LOW.. If the transfer case shot, it is my linkage?/???? .. any advice would help..
sorry for the novel....thanks. mike d
Stoobie's YJ
PostPosted: Wed Jun 28, 2006 2:25 pm    Post subject: Reply with quote
Could be worse, coulda been stuck in 2 HI at the top of a trail... Think your XFer case is hosed guy.... shock
