No Heat, need help
leadsled
PostPosted: Mon Jan 16, 2006 2:33 pm    Post subject: No Heat, need help Reply with quote
Occured about a 3 days ago.
1996 Jeep Grand Cherokee Limited
-No heat from the interior heater.
-Engine temp rises much faster, than prior to having no heat.
-Engine temp rises noticably higher than normal, however not to the overheat point.
-Radiator has full fluid.
Thermostat??
Please Help!! Freezing my butt off here in PA
Josh
[/b]
riverzendz
PostPosted: Tue Jan 17, 2006 7:47 am    Post subject: Reply with quote
Thermostat
Clogged radiator
Clogged radiator hose
Heater core issue
Do you smell coolant? Does the resovoir tank have anything in it?
2008 JK X
1994 JGC Laredo - SOLD
fireguy08
PostPosted: Wed Jan 18, 2006 7:36 pm    Post subject: Reply with quote
sounds like a bad thermostat.but if you smell antifreeze then it's probable the heater core.
95 zj limited 5.2l,242,2"bb,dynomax,kn intake
